Samurai 20V Posted May 3, 2011 Share Posted May 3, 2011 @Samurai, the Unichip is capable of adjusting duty cycle & boost.......... Read the web write up, you are correct, it does do boost control, although no details on how exactly.. It says that you can have up to five maps, how do you swap between them? It might be handy with the fuel situation in SA to have a map on pump fuel only, and another for a high octane mix.... I used to own a Corolla RXi 20V, they were famous for not being able to be chipped, the OEM ECU used to always put the car into limp mode after some time, I hope the Supra is not the same.. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 3, 2011 Share Posted May 3, 2011 Read the web write up, you are correct, it does do boost control, although no details on how exactly.. It says that you can have up to five maps, how do you swap between them? It might be handy with the fuel situation in SA to have a map on pump fuel only, and another for a high octane mix.... I used to own a Corolla RXi 20V, they were famous for not being able to be chipped, the OEM ECU used to always put the car into limp mode after some time, I hope the Supra is not the same.. I'd definitely go the HKS route if you have a pro dealer available locally, mine never missed a beat. Quote Link to comment Share on other sites More sharing options...
Samurai 20V Posted May 3, 2011 Share Posted May 3, 2011 I'd definitely go the HKS route if you have a pro dealer available locally, mine never missed a beat. Still need to check there reputation but they are authorized HKS so thats at least a good thing.. Quote Link to comment Share on other sites More sharing options...
