What size piping should i use on external wastgate (single)
spiderpigcity
is 6mm id ok to use for piping from external wastegate to turbo and boost solenoid?
also i have boost solenoid and cant remember what size fitings i need to screw into it?
is it 3/8 bsp?
Has anyone got a diagram for the solenoid setup, i cant remember which ports are connected to what. i have 1 on the left 3 in the middle and 2 on the right. if i remember one of the ports is not used. do i leave the port thats not used vented?
its about 3 years ago since i worked on this car and i have forgot most of what i used to know.
