Durandal Posted April 30, 2011 Share Posted April 30, 2011 Hi guys, I'm having a problem with a howling noise coming from my engine bay kind of like what you would get if you blew air across the top of a bottle. Could this be belts? Or maybe a vacuum leak. It happens at idle and while driving. Also I finally update my garage with some picture, cheers. Link to comment Share on other sites More sharing options...
bradleyh_15 Posted April 30, 2011 Share Posted April 30, 2011 Hi guys, I'm having a problem with a howling noise coming from my engine bay kind of like what you would get if you blew air across the top of a bottle. Could this be belts? Or maybe a vacuum leak. It happens at idle and while driving. Also I finally update my garage with some picture, cheers. Video or sound bite? Link to comment Share on other sites More sharing options...
jevansio Posted April 30, 2011 Share Posted April 30, 2011 Split hose or hose which is just about to come off (I'm talking boost here so turbo -> FMIC -> throttle pipes) Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Share Posted April 30, 2011 As above, boost leak somewhere? Link to comment Share on other sites More sharing options...
mikeyb10supra Posted April 30, 2011 Share Posted April 30, 2011 is it a u s/ukspec?? could be the dreading death whine Would suggest intercooler coupling split or loose as others have mentioned Link to comment Share on other sites More sharing options...
Scooter Posted April 30, 2011 Share Posted April 30, 2011 pop the hood and check your fan spins relatively freely by hand.... Link to comment Share on other sites More sharing options...
Durandal Posted April 30, 2011 Author Share Posted April 30, 2011 Its a jspec. I just did a boost test on the IC piping last year but maybe I will check that again Link to comment Share on other sites More sharing options...
madwoody1 Posted April 30, 2011 Share Posted April 30, 2011 could be the bottom crank pulley mine mad that sort of noise Link to comment Share on other sites More sharing options...
Abz Posted April 30, 2011 Share Posted April 30, 2011 Would be good if you could get a video of it up, might help out. Also do you have a FMIC fitted? Link to comment Share on other sites More sharing options...
Durandal Posted April 30, 2011 Author Share Posted April 30, 2011 I just took it for a rip to test turbo spooling through several gears all which seemed fine. The fans spun decently while the engine was off. I noticed the noise again on the way back while cruising in 3rd gear at around 2600 RPM but it sounded more like a bearing now that I listened to it some more. I'm pretty sure it's on the serpentine belt system. The fan looks like it has a bit of a wobble to it while running. I always thought that was kind of normal though. Do your fans look a bit wobbly while spinning? Link to comment Share on other sites More sharing options...
bobapple Posted April 30, 2011 Share Posted April 30, 2011 Hope your noise isn't like this I have had some bearings go in the pulley system at the front of the bay you can definitely hear them if it is them they get v.loud Link to comment Share on other sites More sharing options...
Calorus Posted May 1, 2011 Share Posted May 1, 2011 When you say "Death" Whine - do we know what the final cause of death was? Link to comment Share on other sites More sharing options...
Josh Posted May 1, 2011 Share Posted May 1, 2011 When you say "Death" Whine - do we know what the final cause of death was? I think "death whine" refers to the turbo/s being on their way out. If it's happening at idle too then it's unlikely to be the turbos themselves. Link to comment Share on other sites More sharing options...
madwoody1 Posted May 1, 2011 Share Posted May 1, 2011 have a look here http://www.jack-frost.co.uk/toyota_supra_crank_pulley.html Link to comment Share on other sites More sharing options...
Scooter Posted May 1, 2011 Share Posted May 1, 2011 I just took it for a rip to test turbo spooling through several gears all which seemed fine. The fans spun decently while the engine was off. I noticed the noise again on the way back while cruising in 3rd gear at around 2600 RPM but it sounded more like a bearing now that I listened to it some more. I'm pretty sure it's on the serpentine belt system. The fan looks like it has a bit of a wobble to it while running. I always thought that was kind of normal though. Do your fans look a bit wobbly while spinning? I don't think they do...........i would take off the large fan belt and then hand turn the upper pulleys and see if I can feel loose/roughness/play in any. You could run it briefly like this from cold and see if without this belt the noise is gone. Link to comment Share on other sites More sharing options...
bobapple Posted May 1, 2011 Share Posted May 1, 2011 If the belt looks wobbly while spinning you may have a buckled pulley causing strain on the bearings. Link to comment Share on other sites More sharing options...
fastnfurious Posted May 1, 2011 Share Posted May 1, 2011 suggest you thoroughly check the followings: - crank pulley (it will delaminate over the years and break into 2 pieces!) - V-belt tensioner pulley - vacuum hoses (possible leakage somewhere) - 1st turbo (death whine = f*cked up turbo!) and last but not least, check if there's a Gremlin hiding under the hood... Link to comment Share on other sites More sharing options...
mikeyb10supra Posted May 1, 2011 Share Posted May 1, 2011 the j-specs dont whine like the uk's do when there about to blow. The j-specs usually fire themselves out through the exhaust so your going to know if its that Link to comment Share on other sites More sharing options...
Durandal Posted May 1, 2011 Author Share Posted May 1, 2011 Thanks for all the replies guys, I'm almost sure its a bearing starting to go in one of the pulleys in the belt system. I will update my findings when I get some time and a new belt. Link to comment Share on other sites More sharing options...
Durandal Posted May 9, 2011 Author Share Posted May 9, 2011 (edited) Ok I'm pretty sure its the tensioner but I'm not sure if I should order a whole new tensioner assembly or an individual part. I'm guessing the wearing part in this is going to be the absorber or the bearing in the wheel. What usually goes wrong with these? Edit: I'm getting ready to do my 96000km service and will be changing the coolant, thermostat, rad cap and vbelt. Is it common practice to change the water pump at this point? Edit2: Someone on Supraforums.com list Drive Belt Tensioner 16620-46070 LIST 195.34 COST 142.10 [6SPD] Water pump 16100-49846 LIST 127.70 COST 92.89 Upper out gasket 16343-46030 list 3.20 cost 2.32 bypass o rings 96761-24023 2.46 cost 1.79 ea x 2 Front main seal 90311-46001 list 10.57 cost 7.65 Drive belt 90916-02310 list 66.06 cost 48.05 Timing belt 13568-49036 list 30.56 cost 22.23 cam seals 90311-40020 list 5.40 cost 3.93 ea x 2 Idler pulley13505-46041 list 73.65 cost 53.58 Edited May 9, 2011 by Durandal (see edit history) Link to comment Share on other sites More sharing options...
Iky Posted May 10, 2011 Share Posted May 10, 2011 I get a slight howling at high speed but assumed it was from wind flowing through the rear vents. Are you sure its not that? Link to comment Share on other sites More sharing options...
