Bailey. Posted April 29, 2011 Share Posted April 29, 2011 Just snapped mine when trying to press the old shifter bushes out, needed asap, anyone pm me if they have one spare?? Link to comment Share on other sites More sharing options...
bignum Posted April 29, 2011 Share Posted April 29, 2011 Is it the actual shifter you need or the alloy cradle, i have a shifter. Link to comment Share on other sites More sharing options...
Bailey. Posted April 29, 2011 Author Share Posted April 29, 2011 Ahh, its the actual cradle that holds the bushes mate, thanks alot though. Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Author Share Posted April 30, 2011 Bump Link to comment Share on other sites More sharing options...
bignum Posted April 30, 2011 Share Posted April 30, 2011 Is there no one near you that can weld alloy, this happened to my bro`s , he got it welded. Link to comment Share on other sites More sharing options...
little num Posted April 30, 2011 Share Posted April 30, 2011 yeh if you cant get 1 send it to me and ill get it welded, i realise your in a rush nut if you cant get 1 then thats the cheaper option. Link to comment Share on other sites More sharing options...
jevansio Posted April 30, 2011 Share Posted April 30, 2011 Pics of the break? Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Author Share Posted April 30, 2011 I think I am going to get it welded, and keep this thread going untill I find one, I will get a pic up shortly,so u can mock, lol Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Author Share Posted April 30, 2011 First post updated with pic Link to comment Share on other sites More sharing options...
bignum Posted April 30, 2011 Share Posted April 30, 2011 Wow how exactly did you manage that? Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Author Share Posted April 30, 2011 I have seen my mate/ mechanic do bushes a million times and did totally different, lol, had a vice, put a 17mm socket to press the bush and another socket the other side on the CRADLE ARM not what I should have done, which would be put a larger socket opposite the bush to press the bush into, don't ask!! Link to comment Share on other sites More sharing options...
pistonbroke Posted April 30, 2011 Share Posted April 30, 2011 The bush in the broken part looks pretty new compared to the ones I've just replaced. Like the others have said, some people have done the same as you and had the broken part welded without issue. When it comes to putting the new bushes in, you don't need to press them in. I put the solid alluminium shifter bushes in the freezer overnight, and heated each ring of the shifter mechanism on the oven, the bushes just dropped in, with no effort at all. Link to comment Share on other sites More sharing options...
Bailey. Posted April 30, 2011 Author Share Posted April 30, 2011 The bush in the broken part looks pretty new compared to the ones I've just replaced. Like the others have said, some people have done the same as you and had the broken part welded without issue. When it comes to putting the new bushes in, you don't need to press them in. I put the solid alluminium shifter bushes in the freezer overnight, and heated each ring of the shifter mechanism on the oven, the bushes just dropped in, with no effort at all. Thanks for the tip, we live and learn. Link to comment Share on other sites More sharing options...
