Wez Posted April 28, 2011 Share Posted April 28, 2011 Hey All, Whats the best way to remove the rear hatch glass and the rear windows, should I order any replacement parts from Toyota before removing either or are the seals reusable? If anyone has the EPC exploded diagrams to help explain that would be great Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 28, 2011 Share Posted April 28, 2011 Might sound obvious but " carefully" the quarters are a bitch... Takes about 30 mins per quarter.... I did a summary of removal in another thread only a couple of weeks ago.... I'll go see if i can find it for u Quote Link to comment Share on other sites More sharing options...
Homer Posted April 28, 2011 Share Posted April 28, 2011 Qtr's can be cut out from the inside using a very sharp blade, it takes some time! I guess the inner trim is already gone, so just slide the blade flat with the window all the way round. The sealant is about 1/2 - 3/4 inch wide so keep going round until the window comes out. Quote Link to comment Share on other sites More sharing options...
Wez Posted April 28, 2011 Author Share Posted April 28, 2011 Qtr's can be cut out from the inside using a very sharp blade, it takes some time! I thought they were bolted in but looking at them earlier I couldnt see how, I have no interior so can access the back of them quite easily. Quote Link to comment Share on other sites More sharing options...
Wez Posted April 28, 2011 Author Share Posted April 28, 2011 Might sound obvious but " carefully" the quarters are a bitch... Takes about 30 mins per quarter.... I did a summary of removal in another thread only a couple of weeks ago.... I'll go see if i can find it for u That would be great Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 28, 2011 Share Posted April 28, 2011 Found it.... Hodge was planning the same.... Offer still stands on the quarter http://www.mkivsupra.net/vbb/showthread.php?238696-Anyone-got-a-how-to-for-removing-rear-quarter-windows Quote Link to comment Share on other sites More sharing options...
Homer Posted April 28, 2011 Share Posted April 28, 2011 I thought they were bolted in but looking at them earlier I couldnt see how, I have no interior so can access the back of them quite easily. Doh, forgot about the bolts The link from RobUK explains is very well though, so that at least answers part of your question I used a stanley blade with some insulation tape around one end, but it was a real fiddle, if you can get a better cutter it would make things far easier. Quote Link to comment Share on other sites More sharing options...
Wez Posted April 28, 2011 Author Share Posted April 28, 2011 Doh, forgot about the bolts The link from RobUK explains is very well though, so that at least answers part of your question I wonder where these bolts are as I couldnt see any earlier Quote Link to comment Share on other sites More sharing options...
Homer Posted April 28, 2011 Share Posted April 28, 2011 I wonder where these bolts are as I couldnt see any earlier They're well hidden Have a look at the thread posted above, it's it not clear I'll get some pics for you tomorrow. Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 28, 2011 Share Posted April 28, 2011 They aren't that big, 6/8mm if I remember correctly, 3 on each side, pretty much one by each corner... Quote Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2011 Share Posted April 28, 2011 http://www.turbosupras.com/pdfs/JZA80%20TSRM/BO.pdf Quote Link to comment Share on other sites More sharing options...
