Crank Walk on 2jz gte
spiderpigcity
Yes pretty much limited to the US, as they have a clutch switch fitted, so as said causes extra wear to the crank thrust bearings when starting, however i am no convinced that is the whole story, the yanks also blame this for front main seal failure, but thats just hear say based and bull.
i was just using this information to decide whether to go single streer disc clutch or twin plate. the twin plate not supposed to cause this. i have heard that many different stories its unreal.
i will only be using the car once a month and i didnt see the point in spending extra on a twin plate, but if its a twin plate i need to stop me form damaging the engine then thats the way i will go.
what do you think?
