mikerunner Posted April 28, 2011 Share Posted April 28, 2011 went to fit 1st decat and it comes off at wrong angle for 2nd decat and touches the gearbox, i got j spec 95 tt 6 speed, confused as to what could be the problem as there is only 3 different 1st cats availble Quote Link to comment Share on other sites More sharing options...
Josh Posted April 28, 2011 Share Posted April 28, 2011 Does it have to go a certain way round? Maybe turn it 180 degrees and see if it fits that way? I'm sure you've tried that all ready though Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 28, 2011 Share Posted April 28, 2011 Sounds like you have a VVTi 1st de cat pipe. I have both new correct pipes, or a VVTi elbow to allow you to use the existing (incorrect) pipe, for sale. Quote Link to comment Share on other sites More sharing options...
mikerunner Posted May 26, 2011 Author Share Posted May 26, 2011 def a j spec tt one, still confused as why it dont come off at the right angle Quote Link to comment Share on other sites More sharing options...
Josh Posted May 26, 2011 Share Posted May 26, 2011 Did you try either mine or Chris' suggestions? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2011 Share Posted May 26, 2011 (edited) That looks like a VVTi pipe to me, and trying to fit that to a none VVTi J-Spec will result in it hitting the bellhousing. I can sell you a used VVTi turbo elbow, which will allow that pipe to fit correctly, or the correct none VVTi J-Spec first de cat pipe. Edited May 26, 2011 by Chris Wilson (see edit history) Quote Link to comment Share on other sites More sharing options...
Robzki Posted May 26, 2011 Share Posted May 26, 2011 As said that doesn't look like my jspec pipe, needs an elbow at the bottom by the looks of it Quote Link to comment Share on other sites More sharing options...
