little num Posted April 28, 2011 Share Posted April 28, 2011 This is still on the car at the moment and had coverd just 46 thousand miles. I will remove it once ive had my op but if your desperate for it then you can take it off yourself. £225 if i take it out or £200 if you do. The ratio for final drive i beleave is 3.76 so will give you higher top end with manual but slower pick up. Should be exactly the same if your auto has a open diff. Link to comment Share on other sites More sharing options...
little num Posted April 28, 2011 Author Share Posted April 28, 2011 Ok diffs out and will be £200 collected, i will take pics shortly. Link to comment Share on other sites More sharing options...
Guest Wlodzx9r Posted April 28, 2011 Share Posted April 28, 2011 What u think is it fit to 5 gears NA??? Link to comment Share on other sites More sharing options...
DamanC Posted April 28, 2011 Share Posted April 28, 2011 Is it a case of unbolt Stock '96 TT Auto Open Diff and straight replace with yours? IE No other bits needed? If so, Ill take it Link to comment Share on other sites More sharing options...
little num Posted April 28, 2011 Author Share Posted April 28, 2011 pics Link to comment Share on other sites More sharing options...
Nodalmighty Posted April 28, 2011 Share Posted April 28, 2011 Will it fit in a MK4 NA Auto, Can you PM me your address? Link to comment Share on other sites More sharing options...
little num Posted April 28, 2011 Author Share Posted April 28, 2011 Sold to DamanC Pending payment. Link to comment Share on other sites More sharing options...
