Guest George89 Posted April 27, 2011 Share Posted April 27, 2011 Hi i just finished my NA-TT conversion and i just realised the TT prop shaft won't connect to the NA diff, Has anyone got a TT diff flange? please i need this ASAP Link to comment Share on other sites More sharing options...
dcarrter21 Posted April 28, 2011 Share Posted April 28, 2011 There about £70 from toyota, i ended up buying one. Link to comment Share on other sites More sharing options...
Guest George89 Posted April 28, 2011 Share Posted April 28, 2011 yeah i just ordered one 30 mins ago! £73! Is that all you needed? or am i going too bump in too more problems Link to comment Share on other sites More sharing options...
Wez Posted April 28, 2011 Share Posted April 28, 2011 I am interested in this as I am going the other way, fitting an NA diff into a TT Can you post the part numbers? Link to comment Share on other sites More sharing options...
Parry_10 Posted April 28, 2011 Share Posted April 28, 2011 think I have a tt diff flange somewhere in the garage as I used a tt diff on my na-tt conversion so I swapped the tt flange over with an na one Link to comment Share on other sites More sharing options...
Guest George89 Posted April 28, 2011 Share Posted April 28, 2011 I am interested in this as I am going the other way, fitting an NA diff into a TT Can you post the part numbers? Companion Flange for the diff part number: 41204-30040 It should connect on too the TT propshaft and NA diff, i will let you know on wensday when i get it! Link to comment Share on other sites More sharing options...
Wez Posted April 28, 2011 Share Posted April 28, 2011 think I have a tt diff flange somewhere in the garage as I used a tt diff on my na-tt conversion so I swapped the tt flange over with an na one Let me know if you have please Link to comment Share on other sites More sharing options...
Parry_10 Posted April 28, 2011 Share Posted April 28, 2011 Im away until saturday so will check then cant remember if I threw it out or not Link to comment Share on other sites More sharing options...
Andrew K Posted April 28, 2011 Share Posted April 28, 2011 I'm also interested in how to do this as I'm taking my auto box out of my N/A and fitting a v161 and prop from a TT. Having the same trouble with prop fitting to N/A diff!! When you change the companion flange, can you just do it from the front by just unbolting it and swapping over or have you got to take all the internals out and do it from inside the diff? Link to comment Share on other sites More sharing options...
David P Posted April 28, 2011 Share Posted April 28, 2011 The correct way is to rebuild and reshim the diff, but the swop can be done externally, but you must tighten the nut back to the exact same position. Why not just swop to a 3.769? Link to comment Share on other sites More sharing options...
dcarrter21 Posted April 28, 2011 Share Posted April 28, 2011 I had issues with mine even after buying this flange. I ended up making 6 individual little bushes to space out the prop. It works fine now though! Link to comment Share on other sites More sharing options...
dcarrter21 Posted April 28, 2011 Share Posted April 28, 2011 If anyone needs it ive got my na companion flange..... The nut is rather tight and you can only get to it with a deep socket. Think its a 36mm, took alot to get it off with the car on axel stands.... Would be alot easier if it was on a ramp! Link to comment Share on other sites More sharing options...
Andrew K Posted April 28, 2011 Share Posted April 28, 2011 The correct way is to rebuild and reshim the diff, but the swop can be done externally, but you must tighten the nut back to the exact same position. Why not just swop to a 3.769? Is the 3.769 a TT Auto diff? Will this also still keep the correct gear ratio as the car is still a N/A!? I bought a N/A torsen LSD diff and was hoping to use that! But having trouble with the prop fitting don't realy want to buy another diff!! Can't I use part of another prop used with the front part of the 6spd prop by any chance? Link to comment Share on other sites More sharing options...
David P Posted April 28, 2011 Share Posted April 28, 2011 The 3.769 is a T.T.auto diff, I have just fitted one to my N/A in readiness of the extra torque from the supercharger. For N/A MT6 you need the 4.083 ratio, but the 6MT prop has the larger flange. For NA-T the 3.769 would be more suitable unless you want max excelleration or like changing gear a lot. Link to comment Share on other sites More sharing options...
