Guest SPARKYRICH Posted April 27, 2011 Share Posted April 27, 2011 Hi people im fairly new to supra ownership and my rear brakes are squeeling like mad and the discs are quite worn. ive been trying to order some discs today but the motor factors are telling me there are two different sizes of rear discs i would check myself but im working away and cant measure the discs. the car is a m reg import manual n/a. any help would be great as i would like to order asap so i can pick them up on the way home and get the car sorted for the weekend. cheers Rich Quote Link to comment Share on other sites More sharing options...
scotty71 Posted April 27, 2011 Share Posted April 27, 2011 (edited) if they are JSpec smalls they will be 307mm or 324mm if facelift (bigger brakes) if they are UK's they will be 324mm Get the tape measure out across the diameter, thats the easy way just seen your working away...... will probs be the 307mm tbh but dont b@ll@ck me if it has bigger fitted Edited April 27, 2011 by scotty71 (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest SPARKYRICH Posted April 27, 2011 Share Posted April 27, 2011 if they are JSpec smalls they will be 307mm or 324mm if facelift (bigger brakes) if they are UK's they will be 324mm Get the tape measure out across the diameter, thats the easy way just seen your working away...... will probs be the 307mm tbh but dont b@ll@ck me if it has bigger fitted /vbb/images/smilies/bbcode_grin.gif /vbb/images/smilies/bbcode_grin.gif cheers matey. i will go for the smaller ones. glad you said 307 as they are loads cheaper Quote Link to comment Share on other sites More sharing options...
Nic Posted April 28, 2011 Share Posted April 28, 2011 NA's were fitted with both brake options, but most have the smaller brakes. If you're unsure which brakes you have post up some pics of the calipers. Quote Link to comment Share on other sites More sharing options...
