Slicknick Posted April 26, 2011 Share Posted April 26, 2011 Well my drivers side window didn't work, the motor just clicked when i used the switch so i read up on here that the regulator is a common failure, i sourced a second hand replacement and just swapped it over, but the same thing has happened, the new regulator just clicks and doesn't move . Could i have just brought another regulator with an identical problem or could there be a problem somewhere else? Any help much appreciated as the door is currently disassembled. Cheers! Quote Link to comment Share on other sites More sharing options...
Slicknick Posted April 26, 2011 Author Share Posted April 26, 2011 I just tried putting my multi meter on the power going to the window regulator, then i push the window up switch i get 12v, but when i push the window down switch i get no voltage, is this normal or does it point to a broken switch? Thanks!!! Quote Link to comment Share on other sites More sharing options...
