uk brake refurb
mellonman
after refurbing my uk brakes i thought i would share the experiance,
jack up car
remove front wheel
fasten disc to hub with nuts
remove pins and anti rattle spring and pads
now go get your self a friend or the mrs
press the brake pedal to push the pistons out and watch closely as the pistons will not come out at the same time i had a 1mm shim to put in between piston and disc ( to stop it before it popped out completely )
proceed to do this with each piston
remove brake hose
clamp brake hose i have braided hoses so clamped 2 plates over the end.
remove the 2 mounting bolts that hold the calipar
remove cylinder boots or whats left of them with a small flat end screwdriver
remove the pistons which are very near coming out the correct way is to put a air line on and push out with air,but i used 2 pri bars carefully on the lip that the boots locate on ( make sure you apply even pressure on the piston so it comes out square)
remove piston seals with screwdriver
now its time for some very fine wet and dry to clean your pistons
also use the wet and dry to clean the inside of the calipar clyinder
grease the piston the seal and boot
put in your new seals
push the piston in evenly
put on your piston boots
put on the boot ring i found best to make the ring one big ring and then slip over boot
put the calipar back on and attach brake hose
replace your brake pads and put all pins and anti rattle spring
bleed your brakes with your helper
get them to pump the brake pedal until your brake fluid is flushed through
make sure that the brake fluid is always topped up
once flushed through as your helper is pushing down on padal tighten bleed valve making sure they hold the brake down and dont come back up for another pump.
whilst bleeding the brakes you should always start at the fervest wheel away from the master cylinder.
well i hope this helps anyone attemping it that can use a search button.
Edited by mellonman (see edit history)
  • 10 months later...
  • 4 years later...
  • 9 months later...
One tip a brake refurber once gave me is with those fiddly dust boots Toyota use, they can be a PITA to get to stay on the caliper body whilst you get the spring rings on that hold them in place, especially if the shoulder they sit on has been corroded over the years. If you make SURE there is NO grease or fluid on the area, and you don't get any grease or fluid on the boots, cyano-acrylate instant glue ("Super Glue") will hod them nicely in place. If we see people walking into A and E with rubber dust boots stuck to their fingers we'll know why, won't we? ;) I do them that way and it makes a fiddly job easier IMHO.
As above, how many times I thought I was going to tare the boots with the spring when it slipped off!
Well worth it tho, what a difference it made. Atleast now I've done them with the stainless steel pistons and pins I don't have to worry about them again.
When i've done them i split the two halves, even after a thorough clean with brake cleaner and compressed air through
the fluid holes i found a large build up of dirt etc that was stuck on the face by the seals that seal the two halves.
Where the light blue arrows are in the photo
For that reason i'd strongly recommend splitting them if you do them.
Thinking about it toyota would of also said not to bolt a 67mm turbo on to the side of the engine doesnt mean its wrong though ;)
Agreed.
The calipers are only two pieces held together with 4 bolts, nothing tricky in taking them apart and putting back together other
than they need to be spotlessly clean
Has anyone ever used ultrasonic cleaning to get their caliper halves clean?
/QUOTE]
I've cleaned motorcycle carburetors with ultrasonic and it worked very well
I media blasted the calipers in the photo i posted
  • 2 weeks later...
I found these punch pins extremely useful for removing the horrid, corroded pad retention pins. I had to bash mine out and whilst you can try and use an old pin to do it they bend easily and don't allow you to apply enough force.
I also found that if you can get the pin to move a good cm the right way they knock it back again and dremel/cut the end off where the clip goes. That way when you knock it carefully back out you have an little room in the pin retention hole to place the punch pin into and knock the stuck one all the way out. WD40 of course helps. Just clean the entire area with brake cleaner afterwards and ideally use a compressor to remove any dust/dirt particles.
  • 3 years later...
I just found them on ebay and very cheap but please check the numbers etc and price at Toyota before
ordering, i have never used the ebay seller or Amayama
https://www.ebay.co.uk/itm/4773114110-Genuine-Toyota-PISTON-FRONT-DISC-BRAKE-47731-14110-/182340536875
Or
https://www.amayama.com/en/part/toyota/4773114110
Or try the traders on here who might beat these prices
