HU, Antenna and mirros electrical failure! PLz. help!
Lacoste82
Yesterday i was driving home, and suddenly the Hu shut down, the active antenna wouldnt go up/down and the adjustment for the side mirroes wasnt working either.
I just went through the fuse boxes, the one inside the cabine aswell as the one in the engine bay, and i found no blown fuses!
Im thinking it could be a ground wire, mounted on the chassis somewhere!?
But other than that im clueless as where to look for the problem!
Please, im hoping someone could point me in the right direction![sAD][/sAD]
Thanks in advance!
Found the flaw, turned out it was a fuse, was burned almost inside the not visible part, the metal string thats visible is instact, only a small brown mark from the heat gave it away. apparently the fuse Rad no 2 (7,5 amp) is shared by the Hu, mirrors and antenna.
