Suprachargedtt Posted July 2, 2005 Share Posted July 2, 2005 I have a new steering wheel and boss kit to fit to the sup, I havent a clue where to begin! My steering wheel has an airbag and cruise control. I have the correct boss but how do i remove the wheel? is it an easy job?? Is there instructions i can read on how to do this?? James Link to comment Share on other sites More sharing options...
merckx Posted July 2, 2005 Share Posted July 2, 2005 Try typing steering wheel removal in the search box, and by magic : http://www.mkivsupra.net/vbb/showthread.php?t=27520&page=1&pp=15&highlight=steering+wheel+removal Also, these on Supraforums Its really easy. 1. Unhook your battery 2. Pop the 2 little cover of the sides of you steeringwheel 3. Unscrew the Torx screws behind the covers 4. Slide out the airbag 5. Unhook the 2 harnesses (the one for the airbag has a locking device over it, just push in the tab and it will swing up, then push the other tab and slide out the connector) 6. Use a socket and unscrew the nut in the center of the wheel (19mm I think) 7. Make a note of the position of the steeringwheel 8. Grab the wheel at 3 & 9 and wiggle it off (no steering wheel puller needed) 9. Reverse instructions to put the other wheel back on 10. Have a drink. or There are 2 good ways to get the steering wheel off IMO... 1st, steering wheel puller, my weapon of choice. 2nd, leave the nut on with a few threads, then pull the wheel off with your hands, you can hit the back of the steering wheel on opposite sides as well, it will loosen it up, I use this technique at the junkyard when I forgot my puller, lol. If you don't leave the nut on the threads you may smoke yourself in the face... I haven't ever done it, but I've seen it done or You'll need a Torx set (#25 bit I think), a flathead screwdriver, and a 19mm socket with an extension. I didn't need to use a steerinwheel puller. Have the steeringwheel perfectly straight. Unhook your battery, take the two access panels off the side of the steeringwheel and then use a the torx key and take the screws out. Carefully lift the horn/airbag off and unhook the 2 harnesses (the airbag harness has a special lock you have to unclip, it's pretty straighforward) Once you have the airbag off, just hold the wheel tightly and unscrew the nut. Make a note of the wheel position grab it @ 3 and 9 o'clock and wigle it off. Link to comment Share on other sites More sharing options...
Suprachargedtt Posted July 2, 2005 Author Share Posted July 2, 2005 Link to comment Share on other sites More sharing options...
merckx Posted July 2, 2005 Share Posted July 2, 2005 Your welcome, hope it works . Link to comment Share on other sites More sharing options...
