Swirl mark removal
The Raven
It will, but you will need a machine polisher to use it with, check out some of the threads in the Invisible touch detailing section.
If you're looking to use something by hand, you wont remove the swirls, not before your arms drop off anyway
I have a machine polisher, until now i have only used machine glaze,and polishes ect
However the car in question is red and shows up swirls really bad i have used g3 before after a spray job and was unsure if it was over kill to use it while removing swirls ect.
I will have a read up
