Blackie Posted April 23, 2011 Share Posted April 23, 2011 The little orange engine light used to come on every so offern but now it's on permanently, should I be worried? It runs "oddly" when it's on. It's getting plugged in to a launch diagnostic on Tuesday Link to comment Share on other sites More sharing options...
Scott Posted April 23, 2011 Share Posted April 23, 2011 Which orange light? The Oil one? It generally shows low oil level bud Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 What do you mean by "oddly"? If it's running lumpy it will be your coil pack clips mate. Had it on mine and changed the clips over, never had it since. Link to comment Share on other sites More sharing options...
Jellybean Posted April 23, 2011 Share Posted April 23, 2011 Its this guy Scott; Blackie check out this thread and see what code it is storing. http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes&highlight=engine+light Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 Which orange light? The Oil one? It generally shows low oil level bud Lol cheers for that Scott I mean the one that looks like a little engine, in the right hand light cluster it's the one on the left Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 What do you mean by "oddly"? If it's running lumpy it will be your coil pack clips mate. Had it on mine and changed the clips over, never had it since. Yes quite lumpy, would it show up on a diagnostic as them? Expensive? Its this guy Scott; Blackie check out this thread and see what code it is storing. http://www.mkivsupra.net/vbb/showthread.php?35920-How-To-Check-the-diagnostics-codes&highlight=engine+light http://www.bestcarsguide.com/wp-content/uploads/2009/12/Engine-Light.jpg Cheers chap, think I'll wait for the launch though rather than struggling Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 Like it's not running on all cylinders? Defo the clips, nah not expensive at all. They were defo under 25 quid when I get them for all 6. If I remember correctly it will be fault code 14. Link to comment Share on other sites More sharing options...
Jellybean Posted April 23, 2011 Share Posted April 23, 2011 coil pack clips are 2-3 pound , you need six but sounds like an ignition error alright Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 This is them mate http://whifbitzperformancetuning.co.uk/toyota-supra-supra-ignition-parts-toyota-p-1552.html Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 (edited) Like it's not running on all cylinders? Defo the clips, nah not expensive at all. They were defo under 25 quid when I get them for all 6. If I remember correctly it will be fault code 14. It feels like it's running normally just "lumpy" are the clips easy to change? Forgot to mention it only runs lumpy when the light comes on Edited April 23, 2011 by Blackie (see edit history) Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 Yea there easy just abit fiddly. There is a "how to guide" in the technical section mate. Link to comment Share on other sites More sharing options...
Homer Posted April 23, 2011 Share Posted April 23, 2011 Have you checked the error codes yet Al? If not, that's the first thing to do No point taking it anywhere to check for diagnostics, they will only tell you the same as the DIY error code check in the link Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 Have you checked the error codes yet Al? If not, that's the first thing to do It's going in for diagnostics on Tuesday, hopefully that should bring something up. I really am not too sure about doing the paperclip bridging test for the error codes Link to comment Share on other sites More sharing options...
Homer Posted April 23, 2011 Share Posted April 23, 2011 It's really easy, nothing more complex than in the thread Ian made. It'll tell you right away what the problem is. Without it this thread is pretty pointless as there could be dozens of things causing it IYSWIM Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 Mate honestly it's nothing special, bit of wire between E1 and TE1 then turn the ignition on. Theres no point paying someone to do a 2 minute job. Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 I will give it a crack tomorrow then, how do I work out which pin outs are E1 and TE1 in the diagnostics port? Link to comment Share on other sites More sharing options...
Homer Posted April 23, 2011 Share Posted April 23, 2011 Flip the diagnosic port cover open and the pinouts are printed on a sticker on the inside of the lid. Simples Link to comment Share on other sites More sharing options...
Rob W Posted April 23, 2011 Share Posted April 23, 2011 When you open up the lid it shows what is what. Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 Flip the diagnosic port cover open and the pinouts are printed on a sticker on the inside of the lid. Simples When you open up the lid it shows what is what. Lol cheers chaps, I haven't ever ventured in there, I will post up some codes tomorrow then. Cheers for the help Link to comment Share on other sites More sharing options...
Kirk Posted April 23, 2011 Share Posted April 23, 2011 http://www.mendhak.com/extras/team_america_wave.gif Link to comment Share on other sites More sharing options...
Blackie Posted April 23, 2011 Author Share Posted April 23, 2011 http://www.mendhak.com/extras/team_america_wave.gif That was my next step Link to comment Share on other sites More sharing options...
Bailey. Posted April 23, 2011 Share Posted April 23, 2011 This aint good mate, Your not having much luck are ya.... Link to comment Share on other sites More sharing options...
hp006 Posted April 24, 2011 Share Posted April 24, 2011 When doing the error codes where are they displayed because nothing flashes on my dash at all. Link to comment Share on other sites More sharing options...
Blackie Posted April 24, 2011 Author Share Posted April 24, 2011 When doing the error codes where are they displayed because nothing flashes on my dash at all. It's the little orange engine light on the right when you turn your ignition on that should flash Link to comment Share on other sites More sharing options...
Blackie Posted April 24, 2011 Author Share Posted April 24, 2011 Just got seven error codes off it 21 main o2 sensor (old code from engine fitting not cleared yet) 22 water temp 24 Intake air temp 31 Air flow meter circuit 41 Throttle position sensor 42 Speed sensor signal circuit (Its been delimeted 47 Sub throttle poss sensor Some of these could be uncleared left over codes from engine fitting, Any ideas what to do? Should i reset the ecu with battery disconection and see if any new codes appear? Link to comment Share on other sites More sharing options...
