Garage Clear out
MKIVDreamer
Hi - I used to be active here about 4 years ago - until sadly I had to part with my Aero GZ :(
Never mind, I am moving to Australia and have found the following in my garage which may find a happy home here. If not, flea-bay it is ;)
Will posting if required otherwise pick up please.
PM me if you are interested. I'd rather clear them out so sensible offers will be accepted.
1. Used 9" Electric Car waxer/buffer - Double Insulated pad with 3x applicator pads (one used) and 3x Buffing pads (1 used). Unboxed. £50
2. Brand new, never used Resistanz Car Cover - originally souced from Argos will fit a MKIV. £30
3. Brand New Vertex HID conversion kit 35W 9005 (HB3) 6000K - £50 - potentially sold
4. Used Halfords 2.5 tonne Hydraulic Trolley Jack. £20 Provisionally Sold
5. Used pair of Halfords 3 tonne Axle Stands. £10
Provisionally Sold
6. Full set of PRINTED workshop Manuals bought from one of CJs original runs. £45
7. Used 5l (~3.5l remaining) of Fuchs Silkolene Pro S 10W-50. ~£20?
The following items are available FOR FREE!
Brand new, Turtle Zip Wax 1l. (worth ~£2)
Various 3mm & 5mm Blue LEDs + Resistors
Used Half full bottle of Meguiars Tech Wax
Novus Plastic Polish set (good for cleaning J-spec plastic headlights)
Cheers!
Simon
Yes. From the looks of it this is a rip and replace kit - i.e. take the originals out and replace with this HID kit. Obviously I never got round to fitting myself so I couldn't say 100% certain. I've looked in the box and there are cables/wiring looms, ballasts, brackets, fuses, bulbs and instructions. £40 sounds fine, I'll PM my details.
The Trolley Jack has a 13-41 cm lifting range and if I remember correctly I had to get the front wheels onto planks (1") to get enough clearance to get the jack under the front of the car. http://img30.imageshack.us/i/img03001.jpg/
Axle Stands - http://img9.imageshack.us/i/img03011.jpg/ These are heavy duty. I had my Supe up on these when I had to change the Radiator out. Felt very comfortable under the car with these bad boys taking the strain.
