Guest George89 Posted April 22, 2011 Share Posted April 22, 2011 Hi everyone i just finished my na-tt conversion been a long day! started at 8:30am! anyway the car cranks but won't fire up. It is running Greddy Emanage Ultimate ecu on it and i found a power wire connecting to the Throttle ecu and engine ecu as a T. Its the red wire in the picture. Does anyone know if i should put power through this? i run out of options only thing i could think of the ECU's don't have power going too them, The Emanage does. Link to comment Share on other sites More sharing options...
Ryan.G Posted April 24, 2011 Share Posted April 24, 2011 Check that Pin 31A has power going to it. Single ecu plug, bottom right hand pin which is black/red in colour..... Then check that the spider earthes are on the bottom of the intake manifold. Then check that the red wire on the emanage which i think you have labelled above has power also. Link to comment Share on other sites More sharing options...
