mawby Posted April 22, 2011 Share Posted April 22, 2011 The following pictures are from underneath the car looking up. I was trying to trace where my coolant is now leaking from and to me it looks like the water pump. Am I correct, and is it a DIY job to replace? Quote Link to comment Share on other sites More sharing options...
Ric Posted April 22, 2011 Share Posted April 22, 2011 Radiator out job to change, but easy enough if you got the tools and work methodically, Any where around the front is hard to judge liquids though as the fan could have thrown them around onto surfaces miles from the source Quote Link to comment Share on other sites More sharing options...
mawby Posted April 22, 2011 Author Share Posted April 22, 2011 Those pictures are a bit crappy, this one should be clearer. I've had a good look around, having just replaced the radiator, thermostat and hoses, and the bottom of that pump seems to be the highest point of this latest leak. It's only underneath though and from what looks like a hole in the pump (for draining maybe?) Quote Link to comment Share on other sites More sharing options...
Ric Posted April 22, 2011 Share Posted April 22, 2011 yeah there is a hole in the bottom, it usually has a little rubber hose attached to it, but its opened ended, unsure what its for, pressure release or overflow I'm unsure Quote Link to comment Share on other sites More sharing options...
Scooter Posted April 22, 2011 Share Posted April 22, 2011 Certainly looks like a new pump required http://www.mkivsupra.net/vbb/showthread.php?37289-I-ve-got-a-leak.-HEEEELLLPPPP&highlight=pump+hole Quote Link to comment Share on other sites More sharing options...
mawby Posted April 22, 2011 Author Share Posted April 22, 2011 Yeah it does. I suppose the next decision is do I replace the entire pump assembly, or just the pump without the rear housing (maybe possible to fit without needing to take off the timing belt?), or switch to an electric pump? (Part # Mez WP520) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2011 Share Posted April 22, 2011 That sure looks like the pump. The drain nipple allows leakage past the ceramic seal to exit the pump. Itv usually has a little black rubber pipe on it direct any leakage away from the alternator. I would buy whichever is cheaper, sometimes some pumps WITH backing plates are less than those without. So long as you can get the damper off and are happy removing and refitting the cam belt, timed up right, it's pretty straightforward. It should come with a new gasket, be SURE to scrape ALL of the old one off all mating surfaces. Don't go electric, there's a lot of science in coolant flow, fitting an electric one may well *ugger all that up I have good used pumps.... Quote Link to comment Share on other sites More sharing options...
mawby Posted April 22, 2011 Author Share Posted April 22, 2011 If by happy you mean having never done it and probably not having the tools to do it, then yes I'm happy. A quick look at the EPC shows the little drain pipe you refer to didn't arrive until 06/95. Having watched my coolant leave the pump, drip onto the alternator, and then eventually drip out the bottom of the alternator... I think it was a worthwhile addition. Quote Link to comment Share on other sites More sharing options...
