Wez Posted January 13, 2003 Share Posted January 13, 2003 Hello Guys, I have a HKS EVC IV, got it cheap and was wondering what settings are best to use, I have heard that it is not recommended for the supra but have also seen that some people are using it without problems, why is it not recommended. I saw the below post regarding the settings -------------------------------------------------------- I have set the stock boost to 0.9 bar as that's all I can seem to get out of it while running the third gear test despite having a de-cat and FCD. Having found the stock boost I have set the controller as follows, Low boost 0.9, High boost 1.1, Scramble boost 0.10 (1.2bar) which is set to 30 seconds and I have set the warning to 1.3 bar. The only problem I have is setting up the offset mode. --------------------------------------------------------- Can anyone offer anymore information on this. Regards Wez Link to comment Share on other sites More sharing options...
Nathan Posted January 24, 2003 Share Posted January 24, 2003 Quote Originally posted by Wez Hello Guys, I have a HKS EVC IV, got it cheap and was wondering what settings are best to use, I have heard that it is not recommended for the supra but have also seen that some people are using it without problems, why is it not recommended. : Wez, There are no 'specific' settings that can be applied to any boost controller. Every car will be different. You could copy someones figures to get you in the 'ballpark' but I certainly wouldn't advise it unless you are going to keep a very close eye on boost levels. Even if the boost does just happen to sit on what you want it to be it doesn't mean your boost curve couldn't be better. It has to be said that setting up a boost controller on a Mk4 is something of a black art (trading between offsets and peak boost levels) and even I don't fully understand it. Thats why I got the boys downstairs to sort mine out! The only people who don't reccomend EVC's are people who can't set them up properly.....a word of advice; never use the 'learning' function on Mk4's. Cheers Nathan TDI PLC Link to comment Share on other sites More sharing options...
Wez Posted January 24, 2003 Author Share Posted January 24, 2003 Hey Nathan, Thanks for the info, I got it cheap from a friend who had real problems with it on his MKIV. He sold the unit to me and went for a bleeder T mod instead. He was experiencing very high boost on one turbo and then a huge drop and then more boost, not very smooth boost curve at all, was a while ago now so can`t remember all the details. I think that he was trying to use the learning mode, but I did notice in the english instructions that this was not recommended, I haven`t fitted it yet as I am in the process of getting a boost gauge and EGT done. Kind Regards Wes Link to comment Share on other sites More sharing options...
Mark D Posted January 24, 2003 Share Posted January 24, 2003 What is an EVC anyway? Link to comment Share on other sites More sharing options...
Wez Posted January 24, 2003 Author Share Posted January 24, 2003 Electronic Valve Controller I think Link to comment Share on other sites More sharing options...
Mark D Posted January 24, 2003 Share Posted January 24, 2003 Thanks for that. I have managed to find a site with some explanation and some advice for installing. It is for an Audi S4, but I think it may still be useful to someone. http://home.pacbell.net/gj_os/evc.html Link to comment Share on other sites More sharing options...
JZA80Supra Posted January 25, 2003 Share Posted January 25, 2003 I have HKS EVC IV too, it works fine and set it at 1.1 bar for pump gas Link to comment Share on other sites More sharing options...
Wez Posted January 26, 2003 Author Share Posted January 26, 2003 Hey Guys, Any chance of posting some pics of the valve fitted. I am hoping to fit mine soon and was wondering where are the best places to T into is. Regards Wez Link to comment Share on other sites More sharing options...
Alex Posted January 26, 2003 Share Posted January 26, 2003 Mount the actuator as close the the front-most turbo as possible. Mounting points are limited but also varied depending on your intake setup. Link to comment Share on other sites More sharing options...
Wez Posted January 27, 2003 Author Share Posted January 27, 2003 Thanks for the info. Where is the best place to go through the firewall with the cables? I was also wondering if anyone has some pics showing what pipes I should be connecting the valve too. Kind Regards Wez Link to comment Share on other sites More sharing options...
Nathan Posted February 28, 2003 Share Posted February 28, 2003 We mount the solonoids on the offside of the engine bay, and go through the grommet behind the wheel arch liner, which comes through near the pedalbox. Makes for a nice neat job. Cheers, Nathan TDI PLC Link to comment Share on other sites More sharing options...
Kevin Huntley Posted March 7, 2003 Share Posted March 7, 2003 Doing a search on Supraforums and came up with this info, may help someone:) Functions: Setting the volume knob: Whenever you make an adjustment the settings, you may see a flashing L, turn the knob down (counter clockwise), then it will show a flashing H, turn the knob up (clockwise). Turn it back and forth as instructed until it sets itself. Mode: Allows you to change EVC settings. Hit once for Offset. 2 times for Scramble boost, amount to add to the preset boost (i.e., 0.2bar). 3 times sets the length of time for the "added" scramble boost to last (0-30sec.) 4 times for Overboost Warning Mode. (***This is very important, if it hits higher than the overboost setting, the unit will shut down to stock boost. This will keep you from blowing up your car***) Always set this after you reset the EVC. Put it 0.1 to 0.15 higher than the high boost you are planning on running. Alt: Switches between high and low boost mode. Lights up Green in Low, Red in High Mode. Power: Duh! Scramble Boost: Activates Added boost for the period you set with the mode button. Resetting the EVC: Hold the top 2 buttons along with the lower right button to reset it. (Mode, ALT, and Scramble) Tuning for Supra: Turn the power on and reset the unit. Turn the knob and set your stock boost. (if you don't know it, set it at 0.65, hit the scramble button, and then go to redline in third gear. This is your Max stock boost. reset the EVC and then use this number) Hit the scramble button and then add 0.15 bar to your stock boost (i.e., if your stock boost is 0.9 then enter 1.0) then hit scramble again. Important: Hit mode 4 times to set your overboost. Boost will now be set at you stock boost in low mode. Hit ALT to switch to High Boost mode and enter in how much boost you want. Go do a 3rd gear pull and see if you get the desired boost. If it makes more boost than you want then reset the unit and add 0.5 more to your stock boost (0.2), if you get less, then add 0.5 less (0.1) etc. If you can only get so close, you will have to use the Offset feature. Hit the mode button once, and you will see 100. If you are overboosting, turn it up (between 101-150) if you are underboosting turn it down (between 99-50) TTC Tuning: Reset the EVC. Hold down the ALT and Scramble Buttons (the 2 right buttons) This will put the EVC in Learning Mode and display a L on the screen. In third gear, accelerate until the EVC beeps and displays an H. (this may or may not be to redline. Again in 3rd gear, from the same RPM as the first pull, go all the way to redline and let off. The unit should then beep and show your stock boost. Go ahead and set your overboost and then your desired boost level. If you don't get desired boost (assuming its realistic), or it didn't go from L to H, you need to start from scratch. If you still don't get the desired boost, you can use the offset button explained above to fine tune things. If you can't get the unit to go from L to H, then you are either doing something wrong (i.e., not following instructions or are in Sequential mode). or you have some sort of vacuum or boost leak that is making boost inconsistent, keeping the EVC from learning your boost curve. I take no responsibility for your actions, but as long as you set your overboost correctly you shouldn't be able to blow up anything. For the record all test pulls should be done on a closed racetrack. Link to comment Share on other sites More sharing options...
Wez Posted March 7, 2003 Author Share Posted March 7, 2003 Nice find kevin, thanks. :flame Dev Link to comment Share on other sites More sharing options...
JayRZ93 Posted January 27, 2013 Share Posted January 27, 2013 Kevin Huntley said: Doing a search on Supraforums and came up with this info, may help someone:) Functions: Setting the volume knob: Whenever you make an adjustment the settings, you may see a flashing L, turn the knob down (counter clockwise), then it will show a flashing H, turn the knob up (clockwise). Turn it back and forth as instructed until it sets itself. Mode: Allows you to change EVC settings. Hit once for Offset. 2 times for Scramble boost, amount to add to the preset boost (i.e., 0.2bar). 3 times sets the length of time for the "added" scramble boost to last (0-30sec.) 4 times for Overboost Warning Mode. (***This is very important, if it hits higher than the overboost setting, the unit will shut down to stock boost. This will keep you from blowing up your car***) Always set this after you reset the EVC. Put it 0.1 to 0.15 higher than the high boost you are planning on running. Alt: Switches between high and low boost mode. Lights up Green in Low, Red in High Mode. Power: Duh! Scramble Boost: Activates Added boost for the period you set with the mode button. Resetting the EVC: Hold the top 2 buttons along with the lower right button to reset it. (Mode, ALT, and Scramble) Tuning for Supra: Turn the power on and reset the unit. Turn the knob and set your stock boost. (if you don't know it, set it at 0.65, hit the scramble button, and then go to redline in third gear. This is your Max stock boost. reset the EVC and then use this number) Hit the scramble button and then add 0.15 bar to your stock boost (i.e., if your stock boost is 0.9 then enter 1.0) then hit scramble again. Important: Hit mode 4 times to set your overboost. Boost will now be set at you stock boost in low mode. Hit ALT to switch to High Boost mode and enter in how much boost you want. Go do a 3rd gear pull and see if you get the desired boost. If it makes more boost than you want then reset the unit and add 0.5 more to your stock boost (0.2), if you get less, then add 0.5 less (0.1) etc. If you can only get so close, you will have to use the Offset feature. Hit the mode button once, and you will see 100. If you are overboosting, turn it up (between 101-150) if you are underboosting turn it down (between 99-50) TTC Tuning: Reset the EVC. Hold down the ALT and Scramble Buttons (the 2 right buttons) This will put the EVC in Learning Mode and display a L on the screen. In third gear, accelerate until the EVC beeps and displays an H. (this may or may not be to redline. Again in 3rd gear, from the same RPM as the first pull, go all the way to redline and let off. The unit should then beep and show your stock boost. Go ahead and set your overboost and then your desired boost level. If you don't get desired boost (assuming its realistic), or it didn't go from L to H, you need to start from scratch. If you still don't get the desired boost, you can use the offset button explained above to fine tune things. If you can't get the unit to go from L to H, then you are either doing something wrong (i.e., not following instructions or are in Sequential mode). or you have some sort of vacuum or boost leak that is making boost inconsistent, keeping the EVC from learning your boost curve. I take no responsibility for your actions, but as long as you set your overboost correctly you shouldn't be able to blow up anything. For the record all test pulls should be done on a closed racetrack. Will this setup work on a mkiv supra tt with evc 5? Link to comment Share on other sites More sharing options...
Steve Paine Posted January 27, 2013 Share Posted January 27, 2013 Lee P at SRD set mine up. Apparently there are 2 different set ups one for twins and different for singles. Mine is just set at 1.3 bar boost on A and when off car goes to 0.9 bar. Works well for me! Link to comment Share on other sites More sharing options...
j80leo Posted February 23, 2013 Share Posted February 23, 2013 Anyone know how to unlock the controller so I can adjust the boost in car as mine is locked Link to comment Share on other sites More sharing options...
j80leo Posted February 23, 2013 Share Posted February 23, 2013 I've tried the reset but that does not unlock it Link to comment Share on other sites More sharing options...
j80leo Posted February 24, 2013 Share Posted February 24, 2013 Anyone ?? Link to comment Share on other sites More sharing options...
Guest supra&starlet Posted February 24, 2014 Share Posted February 24, 2014 do you have pictures of where you hooked up the HKS EVC IV under the hood?? I have been trying to get mine to work forever but i just do not understand where i get my hoses to hook up. My HKS EVC IV has settings on it already it just doesnt control my boost at all, its hooked up wrong under the hood Link to comment Share on other sites More sharing options...
