dr_jekyll Posted May 26, 2011 Author Share Posted May 26, 2011 car is positioned for surgery Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 26, 2011 Author Share Posted May 26, 2011 (edited) gently gently VIOLA Edited May 26, 2011 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2011 Share Posted May 26, 2011 I have to wonder just HOW close to the breaking strain of that rope you were there, and I had to look in awe at the confidence you had in your knot tying.... Link to comment Share on other sites More sharing options...
Guest wantthatone Posted May 26, 2011 Share Posted May 26, 2011 I have to wonder just HOW close to the breaking strain of that rope you were there, and I had to look in awe at the confidence you had in your knot tying.... he was in the scouts! got the badges, lol Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 26, 2011 Author Share Posted May 26, 2011 I have to wonder just HOW close to the breaking strain of that rope you were there, and I had to look in awe at the confidence you had in your knot tying.... its ok , i went to boy scouts, the knot was never in doubt. as for the rope, it was fraying so ill play it safe and use an old seatbelt to put the new one in. best do things properly Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 26, 2011 Share Posted May 26, 2011 I keep looking for the knicker elastic an old girlfriend had, amazing stuff, all my cunning, best chat and gifts failed to get it to stretch over her hips. Link to comment Share on other sites More sharing options...
AlexM Posted May 26, 2011 Share Posted May 26, 2011 I keep looking for the knicker elastic an old girlfriend had, amazing stuff, all my cunning, best chat and gifts failed to get it to stretch over her hips. Sounds like remarkable stuff Chris, good luck in your hunt. Link to comment Share on other sites More sharing options...
SupraDan24 Posted May 27, 2011 Share Posted May 27, 2011 VIOLA http://www.mkivsupra.net/vbb/attachment.php?attachmentid=133369&d=1306435747 So where does the Viola go? :D Link to comment Share on other sites More sharing options...
J_Supra_07 Posted May 28, 2011 Share Posted May 28, 2011 I can bring lifting straps or chains to put it back in. Good work tho. I saw it yesterday with the engine out. Makes me want to do it again. I'll be over later to grab your turbo for ya. Link to comment Share on other sites More sharing options...
Ricardod Posted May 28, 2011 Share Posted May 28, 2011 (edited) Looks awesome, respect to the owner and builder of this beast! I finally finished my NA-T build aswell, i share the same turbo as you do and darn do i like that turbo. it spools up at around 2500-3000rpm and has full boost between 3250-3750rpm (no turboback exhaust, still have to fit mine) XS T61's are VERY cheap and seem to be up for the task too. Only thing left for me to do is map my car and replace my MAP sensor as it took a crap on me along with the ''air pulsation damper'' thats attached to the MAP sensor and intake mani (because of my own stupidness >. Ive got a question about your software mapping, if you dont mine me asking what did you do to your timing? i set my duty cycle to an extra 30% under 8.7 psi of boost and did nothing to my timing yet. Also what oil are you using in your engine and tranny? Keep up the good work! a fellow NA-Ter from The Netherlands Edited May 28, 2011 by Ricardod (see edit history) Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 28, 2011 Author Share Posted May 28, 2011 cheers mate, on the final map we ran 6 deg btdc of tmeing on stock compression. made the car alittle less responsive but allowed it to run 10psi without det on 99 fuel and thatt made about 400bhp. at the moment i had fuches titan 75-90 gearbox oil and fuches titan 10-40 in the engine i think on this engine ill go for the fuches titan 10-50 after i use the halfords mineral oil to run it in Link to comment Share on other sites More sharing options...
Ricardod Posted May 28, 2011 Share Posted May 28, 2011 (edited) so you mean that on the final map you retarded the timing by lets say 4 degrees of the stock 10 degrees BTDC timing? What voltage did you put your voltage clamp too? i set mine to 4.3V is this correct? What air fuel ratio do you guys use as a save standard? 400bhp flywheel or rearwheel horsepower? sorry for all these questions but im trying to learn how to map my NA-T. Thanks for the info! greatly appreciate it Edited May 29, 2011 by Ricardod (see edit history) Link to comment Share on other sites More sharing options...
dr_jekyll Posted May 30, 2011 Author Share Posted May 30, 2011 (edited) yes thats rite. mine is at 4.3 also . the afr hovers around 14.5 on a cruse and is around 11-11.5 on full boost, that was 400 fwhp Edited May 30, 2011 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
Ricardod Posted May 31, 2011 Share Posted May 31, 2011 thanks for the info, appreciate it! and keep up the good work! Link to comment Share on other sites More sharing options...
J_Supra_07 Posted June 1, 2011 Share Posted June 1, 2011 Turbo mod Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 1, 2011 Author Share Posted June 1, 2011 (edited) few progress pics from tonight. as you can see above the lovely turbo mod from jason that takes the rubber coupler away from the hot manifold so tonight with jasons help we slotted the engine into its new home . few little things to do tomorrow and she should be redy to turn the key ( crosses fingers) All the old bits moved over from the old engine and new tubby fitted flywheel , clutch and gearbox fitted , with jason using his hamer hands to tighen the last bolts and shes in , nice and snug Edited June 1, 2011 by dr_jekyll (see edit history) Link to comment Share on other sites More sharing options...
HadeS Posted June 2, 2011 Share Posted June 2, 2011 Nice update mate. I'm wondering how long gearbox will last Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 2, 2011 Author Share Posted June 2, 2011 forever at this point , having eletrical issues. the thing wont crank. not getting a feed to the small wire on the back of the starter motor. but confused at the moment. Link to comment Share on other sites More sharing options...
Parry_10 Posted June 2, 2011 Share Posted June 2, 2011 nice work hope you sort the electrical issues and get it running, noticed the meister r coilovers-same as mine Link to comment Share on other sites More sharing options...
J_Supra_07 Posted June 2, 2011 Share Posted June 2, 2011 turn over foult fixed . Small fuel leak to see too then sould see life. :-) Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 2, 2011 Author Share Posted June 2, 2011 bit concernd its not going to fire, even with the small fuel leak it should have atleast tryed to fire a little bit. but nothing just turning over. im not pleased Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 6, 2011 Author Share Posted June 6, 2011 its alive..... allliiiiiiivvveeeee. finally it lives. just let it idle for 10 mins and its currently on a 2000rpm fast idle for 20 mins. so far all seems good , sound smooth and no leaks to report. Link to comment Share on other sites More sharing options...
ScottC Posted June 6, 2011 Share Posted June 6, 2011 Nice one What was the starting issue? Link to comment Share on other sites More sharing options...
dr_jekyll Posted June 6, 2011 Author Share Posted June 6, 2011 Nice one What was the starting issue? the main issue was the tired idiot doing it . thats all im saying Link to comment Share on other sites More sharing options...
HadeS Posted June 6, 2011 Share Posted June 6, 2011 Nice one mate. Any videos ? Link to comment Share on other sites More sharing options...
