mr hyde. na-t budgit track supra
dr_jekyll
bit on hold at the moment mate , waiting on parts to be deliverd. plus atention has turned to getting the car ready for the euro trip and then getting it back as a track car before the next tss round. but fear not after round 2 its full throttle on the new engine
  • 2 weeks later...
  • Replies 306
so first droped in the tt pistons and i tigtend the big end baring caps
torqued to the specified setting in the manual and marked with a white dot , then a further 90 degree turn :)
after the 90 turn all the white dots are faceing out as shown
Edited by dr_jekyll (see edit history)
next was surface preperation, after cleaning both mating surfaces and ensuring they are flat with a bar :) i cleaned them with alcahol spray to remove all grease and residue that potentially weaken the seal of the head gasket
well after a great weekend tearing around northern france its back to reality and back on the engine
firstly i got a second opinion on my work before being told to proceed
http://www.mkivsupra.net/vbb/attachment.php?attachmentid=132456&d=1305136996
Good luck with this Craig, I am sure you will reach your target.
By the way, your car sounded amazing on the Dragonball Run! :cool:
Lol no worries mate, i'm only joshin. I'm sure they'll be other opertunites for me to kick your mrs out and jump in the pass seat haha. Abz was right though, it did sound awesome. I'll keep an eye on the thread and see how your getting on, i'm sure it will be awsome once its finished. 500bhp from an NA on a budget will show that it can be done.
Now for the cams,
these need to be tightend to the set torque figure slowly in stages. one the caps are all secure the cam needs to be rotated in 120 degree intervals and specific caps fully torqued when there cam is facing up so the valve is closed
And then refit the cam pullys by holding the cam with a 24mm spanner and torquing up the 17mm bolts after fitting the backing plate held in place by 4 12mm bolts
i had a visit from the horsepower fairy :):):)
here we have denso 550cc injectors
a new turbo with a .68 turbine housing ans a .70 compressor housing so will bring my boost in a good 500rpm sooner than my current turbo
here is a new injector fitted to the rail next to a stock 330 and it much thinner to my suprises but im guessing it has som trick up its sleave that allows it to flow at 550
un branded but its the xspower t61 same as my old 1, boosts at 3400rpm and was pretty good, cost £200 to my door so rather than spend a grand on another garret that lasted no longer than my other xs turbo id rather buy 5 of these and put a fresh one on every season
few more pics of the progress
added some colour and rust protection to the block , this shuold make any oil leaks easy to trace
the inlet and injectors fitted
cam belt and pullys all fitted up
Cam covers and sump on and shes basicly ready to go in with a few bits transferred from the other engine .
im hopeing to put it in in 3 weeks . the car could really do with it now but this weekend there japfest, next round 2 of the TSS so the weekend after with the help of nevins and jason weel pull the old one out. drop this one in and then its off to ryan for mapping and fingers crossed 500 horses :)
  • 2 weeks later...
