Transmission Mount & Noise Questions
jevansio
I am trying to put my OEM tranny mount back on, I put the TRD mount on and didn't have any trouble, but the shifter cradle was out the way when I fitted it. Now I'm coming to put it back one of the bolts holding the tranny mount to the tranny is impossible to get a socket on, or even a spanner. Am I going to have to undo the bottom 2 cradle bolts, remove the shifter, then swing the cradle to get some room, or is there a cleverer solution?
Also while under there I was spinning the prop backwards & forwards & I think maybe a some of the noise could be coming from the universal joint right where the prop exits the tranny. There isn't obviously a great deal of movement, but there is a definte noise when rotating the prop backwards & forwards. Is this normal?
