Woodwork
penguin
Are you talking Yankee Workshop or MDF?
I make my own wardbrobes but only with standard MDF, fibre board and smooth pine and just make it up as I go along. I'm talking about fitted wardbrobes not fancy standalone jobbies. One of our rooms is an L shape, so I sealed of the L part with door made to look like the wall, skirting etc and push fixings. You push the wall and it reveals small walk in wardrobe. I like to keep my batman suit in there.
sounds cool!!! i'm on about MDF batman :) i was thinking of a standalone jobbie but that's too advanced for me at the moment - i'll just drill in a few pillars to the wall for stability and take it from there, at the moment all my stuff is in a box :-(
Sounds simple enough, B&Q will have all the materials you'll need though I tend to get the fixings from screwfix as they are a little cheaper (but getting expensive).
What's the fold out bin for? Not rubbish surely? Laundry?
That's really nicely laid out, and I thought it was a veneered MDF at first. It reminds me of an old oak Gents wardrobe I had, with separate labelled shelves for collars, shirts and a pull out trouser rack.
The bin reminded me of this butcher block bin I made for our kitchen, I've since changed the top to a smaller one piece bit of beech, as that was made from offcuts from our previous house, so I changed those black tops to beech block and now it all runs through.
http://img.photobucket.com/albums/v713/aberdeenstu/Wood%20Stuff/DSCN3737.jpg
Yeah its for laundry, it folds forward just so that its easier to reach the bottom because of the shelf above.
I built mine a couple of years ago, started with 2 x door liners and built stud work around them and fitted to the walls and ceiling/floor etc. I used 18mm mdf at the front, as I left the stud work 18mm behind the liners it all finished of nice and flush. I made the left hand side for hanging with shelves on the right, and one big top shelf the whole width. I paid £130 for all the materials, I reckon a wardrobe company would charge a couple of thousand for a similar wardrobe:
Not sure MDF qualifies as wood - lol
It has been a large source of allergic reactions caused by constant low level exposures to preservatives used in it
http://www.lhc.org.uk/members/pubs/factsht/82fact.htm
Slowly the use of formaldehyde in so many things ( especially china made things) is causing concern , a hidden chemical attack on people , not designed for such battles
At work we call it M-Death. :D
It's literally made of softwood dust but it's not really that lethal unless it falls on you! :D
Just wear a dustmask and use a vacuum on your powertools. Also, Medite is the best MDF and you shouldn't sand the faces with anything rougher than 240 grit as it will make it furry. It doesn't need it unless damaged anyway. The edges are a mare to sand and best to run a sharp plane over them and use a solid wooden sanding block. A 5" length of 44x20 pine batten wrapped and duck taped with 100-120 grit red resin aluminium oxide paper is best.
You can brush on watered down PVA adhesive (white wood glue) to seal the edges and make them easier to sand smooth. A special MDF grainfiller is available but I haven't used it since college. I just use elbow grease. It's near the skyhooks and long weights in Homebase ;)
"It's literally made of softwood dust but it's not really that lethal unless it falls on you!"
There are increasing studies that are looking at modern materials and links to allergies,cot deaths ,liver ,kidney and a whole host of things , so called "sick building syndrome" Formaldehayde is one of many proven toxic chemicals in common use along with limonene in food products
The ist world is getting sicker, year on year, the 3rd world is not (they just starve !) asthma is a town thing ,country folk suffer far less, they only have to deal with the crop spraying -lol
I remember a few years ago, I had to throw away approx. 180 mtrs of copper tube, due to an odd corrosion/reaction that was occurring. The surface of it was blistering, and turning purple/green, but only on one side.
We traced it back to One of our installers, who'd be cutting mdf for a few days in the area, and the dust had settled on one side.
I won't cut, or be near mdf being cut without a mask now.
Its also illegal in the US apparently. (but you can go to to your local Walmart and buy a gun! :D )
I heard that MDF was banned in the States but then allowed again but I never looked into it.
The HSE did class hardwood dust as a carcinogen back in the nineties iirc.
It's quite annoying when most joineries and furniture companies let people use sanders without even the dustbag provided, let alone vacuum extraction. I just got turned down for a job which paid £3ph more because I mentioned an orbital sander that was obviously being used without even a bag. The guy made a big deal out of his concerns that there would be friction between myself and the others over dust, all because he didn't think they'd start using even a dustbag on the sanders.
One of the guys had athsma but didn't wear a mask because it made his breathing more difficult, yet apparently was quite happy to stand next to someone all day blowing dust in his face!
It was like stepping back in time 25 years. They were blown away by my work but let that get in the way. I thought evolution was supposed to go forwards. :(
Still, it made me realise how easy I have it where I am now, with only one suicidal maniac blowing dust about. :D
I've noticed his cough getting worse over the years and the machinist who works nearest to him is having difficulty catching his breath now. He cycles to work as well.
I learned about Formaldehyde at college. It's everywhere. Limonene I hadn't heard of.....
Is that D-limonene used variously as a heartburn remedy and laboratory solvent?
Supposed to be safe and derived from citrus extracts from what I just read.
