captainchaos Posted April 14, 2008 Share Posted April 14, 2008 whats the difference between the 2 of these? NGK Iridium - BKR8EIX or BKR9EIX? Link to comment Share on other sites More sharing options...
Alex Posted April 14, 2008 Author Share Posted April 14, 2008 whats the difference between the 2 of these? NGK Iridium - BKR8EIX or BKR9EIX? Coldness. 9 = colder than 8. 9's probably won't run very well in anything short of a built motor with a standalone ECU. 7's for BPU 7-8's for APU (Singles etc) Link to comment Share on other sites More sharing options...
matt k Posted April 15, 2008 Share Posted April 15, 2008 Bought some BKR7E plugs today and they seemed to be pre-gapped to .0275 inches (0.6985 mm ). Link to comment Share on other sites More sharing options...
Guest Marcus1 Posted June 9, 2008 Share Posted June 9, 2008 i have a built motor hks to4z and a hypertune 90mm intake well i was looking at making 600 to 700 rwhp wich heat range ngk iridium plug do you guys recon i should go for 7 or 8 i havnt got a cdi yet but looking at the HKS DLI are they any good? Link to comment Share on other sites More sharing options...
Guest majidnaeem Posted June 14, 2008 Share Posted June 14, 2008 What about NGK IK24 plugs....heard they work well under high boost Link to comment Share on other sites More sharing options...
RobSheffield Posted June 14, 2008 Share Posted June 14, 2008 IK24 are made by Denso Link to comment Share on other sites More sharing options...
Alex Posted June 14, 2008 Author Share Posted June 14, 2008 Indeed thanks Rob, IK24 is made by Denso. The BKR8EIX is the NGK equivilent. Link to comment Share on other sites More sharing options...
jevansio Posted June 14, 2008 Share Posted June 14, 2008 You're a MUPPET - DO NOT ATTEMPT TO GAP IRIDIUM PLUGS!!!! Why shouldn't iridium plugs be gapped, the manufacturers specify a gapping procedure, just because it isn't the same as a copper plugs doesn't mean it shouldn't be followed? Link to comment Share on other sites More sharing options...
tDR Posted June 15, 2008 Share Posted June 15, 2008 Why shouldn't iridium plugs be gapped, the manufacturers specify a gapping procedure, just because it isn't the same as a copper plugs doesn't mean it shouldn't be followed? No they don't - Iridiums come pre-gapped. Link to comment Share on other sites More sharing options...
Guest Marcus1 Posted June 16, 2008 Share Posted June 16, 2008 what heat range would be best for say max 600rwhp single to4z and street driving/ idle quality. ngk iridium 7s or 8s thanks Indeed thanks Rob, IK24 is made by Denso. The BKR8EIX is the NGK equivilent. Link to comment Share on other sites More sharing options...
Steve Posted June 20, 2008 Share Posted June 20, 2008 Just to add to this, the NGK BKR8E plugs are no longer made. Link to comment Share on other sites More sharing options...
jevansio Posted June 20, 2008 Share Posted June 20, 2008 (edited) No they don't - Iridiums come pre-gapped. Yes but where does this advice come from? It sure doesn't come from the plug manufacturers as Denso advise the Iridium plugs can be gapped (just not in the same way as normal copper plugs). With copper plugs you can put the gauge into the plug, tap the plug down then remove the gauge. With iridiums they say that doing this can snap the electrode, hence you remove the gauge before gapping then re-insert the gauge afterwards (hence elliminating any chance of the fragile electrode being snapped while removing the feeler gauge). So where does this "you cannot regap an iridium plug" rule start, surely an iridium plug can be used indifferent applications with different gaps and there's no way a plug manufacturer is going to make the same plug with different gaps (otherwise they would have the same serial number and just another number to identify the gap at which the manufacturer set them at)? I will refer you to Denso's website where it states although there may be no need to gap the plug, it certainly isn't the "don't ever gap iridium plugs" bull that seems to be banded around here like gospel: http://www.densoiridium.com/faq.php So are you still telling me "Manufacturers Don't Specifiy A Gapping Procedure For Iridium Plugs" Brian? Edited June 20, 2008 by jevansio (see edit history) Link to comment Share on other sites More sharing options...
tDR Posted June 21, 2008 Share Posted June 21, 2008 So are you still telling me "Manufacturers Don't Specifiy A Gapping Procedure For Iridium Plugs" Brian? For a start are you a politician putting words into my mouth? I never made that statement. I said don't gap iridium plugs! Have you gapped plugs? Just putting a feeler gauge inbetween the very fine center electrode and ground electrode is likely to damage or break the center electrode on an iridium plug. Even with copper plugs I don't leave the gauge in whilst setting the gap - it's a little by little approach to set the desired gap. Hammering the ground electrode into the center electrode via the feeler gauge inbetween is not a good approach IMO The whole point of the iridium design is not to require a smaller gap than what they are set at (and indeed you do get different gaps which are tagged onto the end of the model code eg. BKR7EIX-11 indicating a 1.1mm gap). Gapping down a copper plug is done to stop the spark getting blown out with the increased cylinder pressures seen in modified applications - IE it's a bit of a fudge! It is however done by many with copper plugs without any real adverse side effects. Still, if you want to burn me over it go right ahead. Hey.... your engine, your choice. Link to comment Share on other sites More sharing options...
Steve Posted June 21, 2008 Share Posted June 21, 2008 Have been trying to find some NGK BCPR8ES for my T67 Supe when it is being mapped. But nowhere even has that part number on there database, the only only one close to it is BPR8ES. Are we 100% sure that the listed number on here is correct? Link to comment Share on other sites More sharing options...
jevansio Posted June 21, 2008 Share Posted June 21, 2008 For a start are you a politician putting words into my mouth? I never made that statement. I said don't gap iridium plugs! Brian, it's in black & white further up the page. I said "Why shouldn't iridium plugs be gapped, the manufacturers specify a gapping procedure". You said "No they don't" This can only refer to "The manufacturers don't specify a gapping procedure" statement. I'm not going to get drawn into an argument over this, I'm not saying we should gap the iridiums, I'm saying that to say they can't be gapped is untrue. Link to comment Share on other sites More sharing options...
tDR Posted June 21, 2008 Share Posted June 21, 2008 My inference was no they don't need / want gapped. Apologies if that wasn't clear! Link to comment Share on other sites More sharing options...
jevansio Posted June 21, 2008 Share Posted June 21, 2008 My inference was no they don't need / want gapped. Apologies if that wasn't clear! Ahh I see Link to comment Share on other sites More sharing options...
tDR Posted June 21, 2008 Share Posted June 21, 2008 Have been trying to find some NGK BCPR8ES for my T67 Supe when it is being mapped. But nowhere even has that part number on there database, the only only one close to it is BPR8ES. Are we 100% sure that the listed number on here is correct? Hi Steve, I think the BP range has a different fitment. The closest match I could find was these: http://www.sparkplugsrus.com/shop/index.cgi?command=list&search=BCR8ES They should be the same fitment with the only difference being the centre electrode insulator isn't projected. They should do the trick I can still find supplies of BKR7E's and BCPR7ES's from a number of places online. Either of these would probably be OK but the colder heat grade is probably sensible. Link to comment Share on other sites More sharing options...
Steve Posted June 21, 2008 Share Posted June 21, 2008 (edited) Hi Steve, I think the BP range has a different fitment. The closest match I could find was these: http://www.sparkplugsrus.com/shop/index.cgi?command=list&search=BCR8ES They should be the same fitment with the only difference being the centre electrode insulator isn't projected. They should do the trick I can still find supplies of BKR7E's and BCPR7ES's from a number of places online. Either of these would probably be OK but the colder heat grade is probably sensible. Excellent, thanks for looking Brian Edit: The local places have them in stock Edited June 21, 2008 by Steve (see edit history) Link to comment Share on other sites More sharing options...
tDR Posted June 21, 2008 Share Posted June 21, 2008 Excellent, thanks for looking Brian Edit: The local places have them in stock Sweet - let us know how you get on with them Link to comment Share on other sites More sharing options...
hadyn Posted August 26, 2008 Share Posted August 26, 2008 Stock TT with 2nd decat running upto 1 bar (stock fuel cut in place) Which is the better iridium plug for this application? Denso IK22 or NGK BKR7EIX Link to comment Share on other sites More sharing options...
tDR Posted August 26, 2008 Share Posted August 26, 2008 I'd always go with NGK's because of the reported failures I have seen and witnessed with Densos. Cheers, Brian. Link to comment Share on other sites More sharing options...
hadyn Posted August 26, 2008 Share Posted August 26, 2008 Yes me too. So which NGK would be the best to go for if I never intend to run more than 1 bar? NGK BKR7EIX or BKR6EIX? Link to comment Share on other sites More sharing options...
tDR Posted August 26, 2008 Share Posted August 26, 2008 I'd go with the 7 heat range - I've always stuck with that and run 1bar most of the time. Link to comment Share on other sites More sharing options...
Jellybean Posted September 23, 2008 Share Posted September 23, 2008 Are the Denso Iridium Plugs not Denso Iridium Power IK20 OR Denso Iridium Tough VK20 http://www.globaldenso.com/cgi-bin/global/plug/euro/4w/4w-plug.cgi?name=SUPRA&filename=4w-89.txt&action=search Link to comment Share on other sites More sharing options...
