Indicator won't work
Silece2k6
hey guys, suddenly my indicators won't work.
wenn I use the switch, nothink happens. no click,click,click or green arrows are going on... Maybe a fuse is damaged? but where is the Indicator Fuse? Does anyone has a Fusebox wiring diagram or something?
and I need the color of wires from the Ignition: so Ignition, Acc and constant +
Is that both indicators? As they both go through the hazard warning switch, if that's unplugged, the indicators don't work
  • 2 years later...
I'll bump this in case anyone else has this problem.
I had the issue today where neither my hazards nor my indicators would work.
Turns out there was a blown 15 amp fuse in the engine bay (hazards) which when replace made my hazards work but not the indicators, and also a blown 7.5 amp fuse in the drivers footwell which when replace made the hazards work.
Might be of use for someone in the same situation as me
