Fitting UK Glass Headlights on Sunday
DaveN
As I have not tackled this before, is there any guidence for removing the plastic lights and fitting the UK Glass lights anyone can share ?
It looks like a simple task ..... :complain: ..... usually this means the opposite.
Anyone had the pleasure ?
It is a relatively simple task. The offside light is the easiest of the bunch. You may or may not need to remove the battery.
The near-side is total bastard. To reach 1 bolt you probably will need to remove the stock airbox - if you have one.
