DaveN Posted July 1, 2005 Share Posted July 1, 2005 As I have not tackled this before, is there any guidence for removing the plastic lights and fitting the UK Glass lights anyone can share ? It looks like a simple task ..... ..... usually this means the opposite. Anyone had the pleasure ? Quote Link to comment Share on other sites More sharing options...
Jake Posted July 1, 2005 Share Posted July 1, 2005 Piece of cake mate. 10mm socket, 6 inch extension and a ratchet are the only tools required. Should be done in less than 15mins Quote Link to comment Share on other sites More sharing options...
Clarkey Posted July 1, 2005 Share Posted July 1, 2005 It is a relatively simple task. The offside light is the easiest of the bunch. You may or may not need to remove the battery. The near-side is total bastard. To reach 1 bolt you probably will need to remove the stock airbox - if you have one. Quote Link to comment Share on other sites More sharing options...
Jake Posted July 1, 2005 Share Posted July 1, 2005 The near-side is total bastard. To reach 1 bolt you probably will need to remove the stock airbox My airbox is on the offside! You only need to remove the airbox lid to get at the headlight nuts Quote Link to comment Share on other sites More sharing options...
Clarkey Posted July 1, 2005 Share Posted July 1, 2005 My airbox is on the offside! You only need to remove the airbox lid to get at the headlight nuts Yeah ... typo sorry! Doh! Quote Link to comment Share on other sites More sharing options...
DaveN Posted July 1, 2005 Author Share Posted July 1, 2005 Cheers for the piece of mind that I will be able to start and finish the job on the same day ! Always nice . Quote Link to comment Share on other sites More sharing options...
lovatt Posted July 1, 2005 Share Posted July 1, 2005 easy peasy mate, if you get scared pop round and ill do it for you Quote Link to comment Share on other sites More sharing options...
DaveN Posted July 1, 2005 Author Share Posted July 1, 2005 easy peasy mate, if you get scared pop round and ill do it for you Good to know matey ....... thanks Quote Link to comment Share on other sites More sharing options...
