hsk fcd nottingham fitting
bigjools
Fitting them is easy mate, just follow the instructions, i'm not sure how you can destroy your ecu with it. It will either work or it won't, if it doesn't then your wiring is wrong so just go over it to find the fault, shouldn't break anything. The wiring diagram for the thor unit is very good and simple and usually it comes pre-setup.
