Hi from the "Other Side"
Guest lexalimited
Guest lexalimited
Hi Guys,
thought I would say a quick "Hi". I'm not actually a Supra owner (although that may change after looking at some of the motors on here) I own a Soarer and as some of you may or may not know they share the same chassis and suspension components although Supra items tend to be uprated due to the more sporty nature of the model.
Which leads on to the main reason I came looking... I want to upgrade my brakes so I'm after discs and calipers if anyone can help.
In the meanwhile it's nice to be a member of the Toyota family!
Hi,
Check out the forsale section for calipers etc, theres been a few sets in there in recent months
but not sure whats still available, if your after the uk spec 4 piston front and 2 piston rear set up
you can buy the whole lot brand new for under £1000
You'll need to make sure your wheels will clear them though as there quite a bit bigger.
