safcdixon Posted April 17, 2011 Share Posted April 17, 2011 I have adjustable h+r suspension on my car and since putting a standard front on ( finally shot of the veilside ) it looks really high at the front, and would like to drop it a little bit, now I have no idea how to do this so any help would be appritiated. Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 17, 2011 Share Posted April 17, 2011 If they are bottom adjustable you simple crack open the locking rings and spin the shock to raise/lower. If they are not bottom adjustable you have to raise via compressing the spring with the locking rings. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 17, 2011 Author Share Posted April 17, 2011 they are bottom adjustable, So I don't have to take any weight off them? It sounds to easy to be true! What would I use to release the locking nuts? Don't think I have anything big enough? Cheers for the quick reply Quote Link to comment Share on other sites More sharing options...
Guest wantthatone Posted April 17, 2011 Share Posted April 17, 2011 check your boot, you may have c spanners Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 17, 2011 Share Posted April 17, 2011 Remove the wheel, unscrew the locking ring and turn clockwise. Attention : 1 inch of drop on the suspension is not necessary 1 inch body drop. Luc Quote Link to comment Share on other sites More sharing options...
JamieP Posted April 17, 2011 Share Posted April 17, 2011 Any weight off? lost me there. You need some coilover spanners really, you can knock them open with a hammer and bar if you are careful. http://cgi.ebay.co.uk/COILOVER-C-SPANNERS-ADJUSTABLE-SUSPENSION-TEIN-CUSCO-/280658056263?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4158861447 Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 17, 2011 Author Share Posted April 17, 2011 Think I might aswell order the spanners they are only a tenner, and don't want to end up braking something By taking the wieght off I meant compress the spirings or loosen the lower wishbone by what you've said I don't need too anyway, how much would I need to drop it for say two inch drop or is it just trial n error? Quote Link to comment Share on other sites More sharing options...
