seba Posted April 17, 2011 Share Posted April 17, 2011 Well i had an accident with my first supra about 1.5 years ago. since then i've had other supras and left the crashed one outside under a cover. Now the time has finally come, Tomorrow they are picking up my supra to fix it, but after 1.5 years of sitting there, winter, summer, what problems can i expect or what should i definitely do or not do? Quote Link to comment Share on other sites More sharing options...
monsween Posted April 17, 2011 Share Posted April 17, 2011 HateEvents car was not started in over a year after a bump. Started on the first turn of the key after a new battery. Your brakes are going to be seized and more than likely need a re-furb. Just ensure that everything is on inside the engine bay and give it a good check over before you start. You can crank it by hand first if you want to make sure everything moves Quote Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted April 17, 2011 Share Posted April 17, 2011 I'd turn it by hand to make sure everything was free, then take off the rotor arm and disconnect the fuel pump and give it a good crank to get some fresh oil around the block before it was started. And as monsween said, the brakes with probably need a going over. And check for rats! Quote Link to comment Share on other sites More sharing options...
