How it got from Stock N/A to Wide TRD TT BPU -Pic Heavy
DodgyRog
  • Replies 762
Posted Images
Ariel Mast done today, very easy job, unfortunately have guests today, so no more time on the Supra again
To do list....................
Get it through the MOT (put a Cat back on etc)
Refurb, get tyres and fit my new wheels Volks GT-N 18x11j and 10j 4 1/2 inch rear dish, 3 1/2 inch front dish
Sort out the coilover height
Make a custom set of arch liners for the fronts with 2 sets of standard liners
get the cigarette and ignition Blue LED from Heckler
Do the custom Dash panel to hold an iPhone 3GS for the Tunes (probably won't get to this before the Dragonball)
Oil Filter and Oil change
Replace the HID Fogs with normal ones
Remove the front bumper, touch up the paint on the inner ducting
Remove the Intercooler, make a bracket so it sits lower and mount it on anti vibration mounts
Move the Intercooling hard pipe into the bumper further to allow the arch trim to be pulled further in to stop the scrubing
Fit the Stock Stereo brackets and replace the Dash Panel, so the Stereo sits inside the Dash Panel to tidy it up
Clean and polish the engine bay, including trying to get a more polished look to the throttle body and Intake
Replace stock front speaker with the Bose ones I have just got
Put new Ariel Mast in
Fit Blue LED window switches
Edited by DodgyRog (see edit history)
Put the 2nd Cat back on today for the MOT in a couple of weeks, but had a bit of a bad surprise
I had to start the Supra and move it onto the blocks to get the Jack under
When I went to get under the car I noticed a line of fluid towards the rear of the car
I then noticed it was dripping from the join in the exhaust, it was water/condensation that should be coming out the back
So I ended up having to remove the whole exhaust and found the flanges were really out of shape (bent???),
I ended up having to Dremel the flanges back very slowly and get them back enough to get a seal with a gasket and gum
It took me about 3 hours, admittedly the Dremel wasn't the speediest tool I could of had, but it was better than my other option which was a file Lol
Anyway took the chance to re polish the back box while it was off, as the diffuser makes it really hard to get at while it's on the car
I will have to do a few more bits tomorrow now as it took so long, but least the forecast is good for most of the day
Oil change and set up the coilovers is the plan for tomorrow, o and sort out the fog lights and tidy the headlight wiring up
  safcdixon said:
Brave man, doing it in the house
Lots of hard graft goes into polishing rims you maybe better with a machine polisher and some cutting compound, takes away most of the arm work
Yeah my arm and fingers are aching, but going and spending £100 plus on a polisher would mean I might as well send them to Ibrar, which I would love to do, but I am skint for the minute
  ScottC said:
Jen was out for the day?
  Abz said:
Jen is currently at B&Q deciding on which tool to use for burying Rog!! :D
Of course Jen was out, she has to work every day to keep me in the lifestyle I am used to lol
Although she came home from work and took the pic, so I think I am safe
Hope she doesn't read that
I got a mop/sander/polisher from toolstation for about £30-40 quid silver(something) was the brand, good enough for stuff like this
It will save you alot of grief theres cheaper ones available too
This one below is the one it has 5/6 speed settings too
http://www.toolstation.com/shop/Power+Tools/Polishers/Sander+Polisher+180mm+230V/d40/sd3309/p84532
Edited by safcdixon (see edit history)
That looks like a good buy for the money, think I am going to have to get one, I am not sure I have the will to do all 4 wheels like this
Spent a few days on this one now and it still has some slight pitting marks left
What sort of pads and cutting compound should I be looking at getting, need to be able get rid of the pitting and then polish them back to a mirror polish
Well I just went with a polishing wheel for the drill
Although I have not quite finished yet and I am going to have to except that I am not going to get rid of the pitting until I can afford to send them to Ibrar
They have come up okay, I need to go over them by hand, as I have a few fine scratches from the drill
This is the one I have only given a quick wash
And the one I am working on
  jazz1 said:
Great job, try britemax metal polish is great stuff aswell.
Yeah got some already
Will be going over the lip a few times with the Easy Cut and then a couple of times with the Final Shine
Bit annoyed I can't do something about the pitting, but I guess that's how the likes of Ibrar earn there money
Not having much work is really hard on the pocket, but it means I can see the light at the end of the tunnel with these wheels now
Weather permitting and they could be finished at the weekend, then I just need to sort out the coilovers to allow these hugely dished rims partly under my arches:cool:
To do list is getting a bit shorter
Get it through the MOT (put a Cat back on etc) then removed again
Fit Blue LED window switches and try and get the cigarette and ignition Blue LED from Heckler
Full Wash and Wax
- - - Updated - - -
  listy said:
Looking good Rog :thumbs:
  safcdixon said:
Those wheels are lovely Rog, good work so far on the refurb
Thanks guys
  Slam said:
Someone has a nice shiny body for sale mate,new.
:confused:
  mattdavies said:
Why the anti-vibration mounts for the intercooler ?
I am using them to lower the intercooler, so it sits better in the mouth of the bumper, the anti-vibration part is irrelevant
Well I now have 3 wheels done, but the Drill has given up on me, just totally died
So next purchase is a new drill, gutted to have not got the last wheel done, as I wanted all next weekend to spend adjusting the coilovers
Time is going to be really against me now to get the new wheels on in time for the Dragonball
Still need to do Oil and filter change and take off the front bumper and re-cut the inner ducting to get the fitment better as well, so I think the wheels are going to have to take a back seat possibly until after the Dragonball now
  safcdixon said:
You sure you havent just overheated the drill? Sometime they heat up and stop but come to life again once they cool down
No mate it has seized, guessing the motor gave up, it was getting slower and slower before it went
