skippyboyo1 Posted April 15, 2011 Share Posted April 15, 2011 Hi guys ive just fitted a system to my supra and before i attempt the following i thought id run it by here i need to get my power wire from the battery through the bulk head....how on earth do i do it??? ive looked and cant see an obvious way throught but im guessing it would come through the passenger side near the ecu? please advise! thanks in advance [OOPS][/OOPS] Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 15, 2011 Share Posted April 15, 2011 Black gromit in the wall on the passinger side If no one else has taken i pic i will in the morning. Quote Link to comment Share on other sites More sharing options...
cje001 Posted April 15, 2011 Share Posted April 15, 2011 I had a big build in mine old Supra, think mine came through the same way as you are suggesting, defo passenger side. Quote Link to comment Share on other sites More sharing options...
scotty71 Posted April 15, 2011 Share Posted April 15, 2011 yeppo definately as above, just look harder Quote Link to comment Share on other sites More sharing options...
djg99 Posted April 15, 2011 Share Posted April 15, 2011 It's a pain getting the wires past the loom but it's the best way to go Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 15, 2011 Share Posted April 15, 2011 Personally, I'd avoid feeding any extra wires through near the loom, unless you're VERY careful about routing the new cable as not to introduce any moisture around the loom/ecu. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 16, 2011 Author Share Posted April 16, 2011 All helpful there guys ill put me glasses on this time and look again!!!! so theres no need to take the offside wheel arch out to do this then no? Cheers Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted April 16, 2011 Share Posted April 16, 2011 All helpful there guys ill put me glasses on this time and look again!!!! so theres no need to take the offside wheel arch out to do this then no? Cheers I ran my power cable out the hole beside the battery, I took the passenger side wheel arch off, tucked it up inside a nice little plastic casing that's already there, through a yellow grommet that heads into the passenger side footwell, then under the carpet in the sill. Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 16, 2011 Share Posted April 16, 2011 (edited) I cut the gromit and passed it in under the carpet and ran it to the back Do you need pictures? Edited April 16, 2011 by The Raven (see edit history) Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 16, 2011 Author Share Posted April 16, 2011 I ran my power cable out the hole beside the battery, I took the passenger side wheel arch off, tucked it up inside a nice little plastic casing that's already there, through a yellow grommet that heads into the passenger side footwell, then under the carpet in the sill. brilliant! thanks TTRickeh Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 16, 2011 Author Share Posted April 16, 2011 I cut the gromit and passed it in under the carpet and ran it to the back Do you need pictures? if you dont mind buddy that wouls be a real help! Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 16, 2011 Share Posted April 16, 2011 Righty, soon as the mrs is done cutting hair, i will go get some. Quote Link to comment Share on other sites More sharing options...
Stan Posted April 16, 2011 Share Posted April 16, 2011 I did the same, gromet above and to the left of the ecu (very hard to see from the engine bay though, so I went from inside the car first then found where it came out by removing the wing). I had to take the wing and arch off as I was using 0 gauge cable which is stupidly thick, but if you are using 4 or 8 gauge you shouldn't have a prob Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 17, 2011 Share Posted April 17, 2011 Seems i was telling a massive lie! The gromit i used it on the drivers side! i did wonder why people where taking off wheel archs. Then ran it under the carpet up and under the rear seats and into the back. Simples I know my engine bay looks crap. But im not doing anything to it until the engine is out Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 17, 2011 Author Share Posted April 17, 2011 Seems i was telling a massive lie! The gromit i used it on the drivers side! i did wonder why people where taking off wheel archs. http://i692.photobucket.com/albums/vv290/quotetheravenuk/SDC12151.jpg http://i692.photobucket.com/albums/vv290/quotetheravenuk/SDC12150.jpg Then ran it under the carpet up and under the rear seats and into the back. Simples I know my engine bay looks crap. But im not doing anything to it until the engine is out fantastic! thanks mate Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 17, 2011 Share Posted April 17, 2011 No problem Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 23, 2011 Author Share Posted April 23, 2011 Seems i was telling a massive lie! The gromit i used it on the drivers side! i did wonder why people where taking off wheel archs. http://i692.photobucket.com/albums/vv290/quotetheravenuk/SDC12151.jpg http://i692.photobucket.com/albums/vv290/quotetheravenuk/SDC12150.jpg Then ran it under the carpet up and under the rear seats and into the back. Simples I know my engine bay looks crap. But im not doing anything to it until the engine is out well would you belive it! came to fit the power wire this morn and where you have gone through the gromit my clutch fluid bottle is there! the gromit you went through must be a blanking hole. I couldnt belive id missed such an abvious place when i saw your pic.......thats because its not there! looks like its offside wheel arch out then.great! happy days! Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 23, 2011 Author Share Posted April 23, 2011 Today i will be mostly.................................................... I ran my power cable out the hole beside the battery, I took the passenger side wheel arch off, tucked it up inside a nice little plastic casing that's already there, through a yellow grommet that heads into the passenger side footwell, then under the carpet in the sill. [GRIN][/GRIN] Quote Link to comment Share on other sites More sharing options...
The Raven Posted April 23, 2011 Share Posted April 23, 2011 Auto DOH Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 23, 2011 Author Share Posted April 23, 2011 Job done told you it would be easy;) Quote Link to comment Share on other sites More sharing options...
Lude Posted April 25, 2011 Share Posted April 25, 2011 i did mine by going.... thro the wing, just by the carbon canister, took the wheel arch liner out to see the wire, then thro the yellow gromet which comes out by the ECU Quote Link to comment Share on other sites More sharing options...
