Mario Posted April 15, 2011 Share Posted April 15, 2011 (edited) Hi guys last year signed up as club member and thought it was time to start a build thread, I'm Mario and purchased a supra Natural aspirated from june 1993 back in august 2009, The car was already undertaken by previous owners so it needed some workmanship to get it the way i wanted my supra. And there it all started. Also very nice to meet you some time in the UK when my car is finished, some pictures of the supra when purchased, First i wanted to get rid of the 2JZ-GE, Some pictures from the conversion, Few new parts installed like a standard N/A clutch and lightened flywheel also an aftermarket fmic was fitted, beceause the previous engine was taken from the supra it was a nice moment for a engine bay respray, so it went to a paintshop before the 2JZ-GTE was lifted in. Some pics of the resprayed engine bay and the tt engine, After the engine conversion i wanted to get rid of the big aftermarket wing which was on the car, also had the glass headlights which were installed a few months earlier but started to get some seal problems, some moisture came inside the headlights, so went to dynamicc polyester centre to get it done, I knew that the W58 was a weak point in my car as its rated to hold max 350 rwhp, but i wanted so bad a little bit more power so went BPU, Edited December 27, 2011 by johnny g (see edit history) Link to comment Share on other sites More sharing options...
Westy Posted April 15, 2011 Share Posted April 15, 2011 Unusual colour! In for the pics! Link to comment Share on other sites More sharing options...
Mario Posted April 15, 2011 Author Share Posted April 15, 2011 For going BPU several parts were needed, -walbro 255ltr/hr fuel pump -greddy boost cut controller -1,2 bar restrictor ring -new oem oil filters including kendall 5 W50 oil -9-12 volt mod -first decat 2,5'' decat Some pics added of the bpu parts installed onto the supra, Already installed on the car were a 3'' TRD high response cat back, 3'' 2nd decat and an fmic, Link to comment Share on other sites More sharing options...
Mario Posted April 15, 2011 Author Share Posted April 15, 2011 thanks, got loads of pictures from the getrag conversion, will upload them right away, Link to comment Share on other sites More sharing options...
Mario Posted April 15, 2011 Author Share Posted April 15, 2011 (edited) When going BPU the boost didn't came above ,8/,9 bar opened a thread in members only section and got feedback from several members over here thanks again for all the response, and learned something, the bpu'd 2JZ-GTE didn't made more then the ,9 bar seen on firts dyno chart. After a few days the W58 didn't survived the gains in power from going bpu, it broke in fourth gear, i made a pull from 90 km/hr to 180km/hr in fourth almost at redline i heard something rattling and had no traction at all, so pulled over and called a service which came across and took my car away, At the garage they found this, several broken teeth which came out of the gearbox when they removed the drain plug, Decided to go with a v160 in combination with an A02B differential, The A02B diff came from an supra TT AUTO, The v160 had some problems in the past with the second gear, and a synchro mesh ring was damaged the gearbox went to NMB MOTORS where they inspected the gearbox and renewed all the parts which were damaged, some pictures added from the gearbox conversion, Also the clutch and flywheel has been changed for stock TT parts, received a used TT flywheel and a new clutch, Edited August 1, 2011 by Mario forgot to add pics of the first dyno chart, (see edit history) Link to comment Share on other sites More sharing options...
Mario Posted April 15, 2011 Author Share Posted April 15, 2011 (edited) With all the feedback given from not hitting the 1,2 bar of boost i decided to go both ways, install a boost controller and get rid of the cat-back which was on, bought an almost new 4'' hks titanium racing which was originally for a nissan skyline, took her to EPS, they build custom exhausts and especially for american cars, So it was kind of funny to walk in with an 4'' exhaust to get it fitted onto a japanese car:), They had a little work on it to make it fit without touching the 3'' 2nd decat which has a 2 bolt pattern flange and the cat back had a v-band clamp, but they managed to fit the exhaust for me, friendly and competent welders over there!!! Supra went on a dyno to get the boostcontroller installed etc and receiving some new data. dyno chart is added. Rear seats are deleted and the floor is covered with an hand made ''Porsche carpet'', At the moment i'm pleased with the results and was getting all parts together for a return towards the stock looks of the supra, parts bought were frontbumper with lip from DC Automotive thanks Dane, clear side markers, original side mirrors(electric) hope the fittings are still beneath the side mirrors which are on the car at the moment, a set of stock skirts and rear spats. Bottomplate for beneath the engine, and some other small bits, The respray is going to be performed by DPC, not really decided yet on the color but still got some time to think, always open for suggestions:) Edited April 15, 2011 by Mario forgot to add picture of the deleted rear seats (see edit history) Link to comment Share on other sites More sharing options...
Mario Posted August 10, 2011 Author Share Posted August 10, 2011 Few days ago my pre-facelift taillights got exchanged for the facelift taillights, didn't knew that they were a straight exchange, but am glad with the newer look of my supra, this will be the very last time you will see my supra in this color:d Link to comment Share on other sites More sharing options...
Mario Posted October 11, 2011 Author Share Posted October 11, 2011 Finally all is coming together now:), after a few bad lucks all seems to be on schedule again, the car is in the paintshop now and they booked some nice progress already for so far, i couldn't take any pictures yet from the car being worked on yesterday but will receive some coming week(so excited but probaply won't be able to read my home mail box at work), brought these parts towards dpc yesterday. And some nice 67mm dbbturbo arrived yesterday from th uk, bought from another forum member. But this littlle friend has to wait till its time to go single:d Link to comment Share on other sites More sharing options...
Supra Gaz Posted October 11, 2011 Share Posted October 11, 2011 Chirst, good work, are you changing the colour of the car? If so what to? Seems a shame to change it to be honest. Nice work though mate, it will be a beauty Link to comment Share on other sites More sharing options...
Westy Posted October 11, 2011 Share Posted October 11, 2011 Facelift lights ftw! They look so much better! What colour are you changing to!? Precision T67-65 dbb? Good choice! Link to comment Share on other sites More sharing options...
Mario Posted October 11, 2011 Author Share Posted October 11, 2011 Chirst, good work, are you changing the colour of the car? If so what to? Seems a shame to change it to be honest. Nice work though mate, it will be a beauty Thanks, i've chosen for 040 white plus 3 layers clear coat on top. Link to comment Share on other sites More sharing options...
Mario Posted October 11, 2011 Author Share Posted October 11, 2011 Facelift lights ftw! They look so much better! What colour are you changing to!? Precision T67-65 dbb? Good choice! It's an Precision T67DBB (6776DBB) .81 A/R Turbine Housing and Large H Size Compressor Housing Link to comment Share on other sites More sharing options...
Mario Posted October 18, 2011 Author Share Posted October 18, 2011 Several pictures i received today of my car being worked on at the moment, Holes where originally were fitted the reflector lights in the rear quarterpanels are closed, also the holes where the rear spoiler was fitted as the areal hole are closed. Also the arches are rolled to fit 11J plus wheels for future needs;). Link to comment Share on other sites More sharing options...
welshbuddy Posted October 18, 2011 Share Posted October 18, 2011 nice build, looking forward to seeing more pictures Link to comment Share on other sites More sharing options...
SupraDan24 Posted October 18, 2011 Share Posted October 18, 2011 Are you spraying it in that garage? Please say your tidying it first lol. Link to comment Share on other sites More sharing options...
Mario Posted October 18, 2011 Author Share Posted October 18, 2011 Are you spraying it in that garage? Please say your tidying it first lol. Totally agree with you, this is just body work preparations, after this Bjorn of DPC will inspect and if all work delegated is perfect, he will collect and drop it off at another employee who works for DPC but is only doing the paint ''part'' , once there it will be resprayed in an controlled area with humidity control heat control etc, after the respray my supra will be there when the paint is hardened, after that part the supra will be transported to DPC again where they will fit all the stock body plastics, except the bonnet, if all the parts are on the supra and fit perfectly, the supra again will be stripped, the parts which needs to be sprayed will be sent to the paintshop to be sprayed in the same color as the car, and will be returned to DPC to be fitted onto my car. I get your concerns, i was really happy to receive the photos from the progress they booked so far, i'm far away at the moment and cannot come over time and time again, really difficult to stay on top of it, it's an expensive respray so hope that the results are worth it. Link to comment Share on other sites More sharing options...
Mario Posted October 19, 2011 Author Share Posted October 19, 2011 nice build, looking forward to seeing more pictures Thanks, hopefully i'll receive more pictures during the respray-process and will update this thread when possible, Link to comment Share on other sites More sharing options...
Mario Posted November 5, 2011 Author Share Posted November 5, 2011 I was able to come over to the paintshop today :dand took some pictures of the progress, one of the frontwings in the actual color, not finished yet, frontwings, waiting to be finished diff. angle fr.wing almost ready for entering the spraycabine. Arches rolled, to fit wider wheel for future needs. Not completely finished yet, Link to comment Share on other sites More sharing options...
Mario Posted November 5, 2011 Author Share Posted November 5, 2011 originally the supra side(skirts) came with an sort of profile, the picture shows new profile, but will be finished in white off course. I was told today that the hole where was fitted the third brake light in which was removed before i got this supra, was filled with an thin plate which was glued, not welded. New plate to fill the hole is welded now, rear hatch is in the correct color but needs to be sprayed again, little marks i was told, i couldn't see them:) Link to comment Share on other sites More sharing options...
Mario Posted November 5, 2011 Author Share Posted November 5, 2011 One of the doors, not finished yet. All is looking well, new bolts, window seals,clips and other small mounting/installation materials are going to be ordered coming week so when the respray is done the body parts can be installed with fresh bolts etc. When finished the c/f VIS racing bonnet will be installed, if i'm not sattisfied with the look of c/f on superwhite, the bonnet will be sprayed too. But will see i really don't know how it will look in the flesh when its on. Link to comment Share on other sites More sharing options...
Westy Posted November 5, 2011 Share Posted November 5, 2011 Good progress on this mate. Should be a a stunner by the time its finished. Only thing I dint like is the third brake light delete, personal taste, but think it looks weird without it!? Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted November 6, 2011 Share Posted November 6, 2011 not kean on the centre brake light removal but this is going to look lovely. makes we want to build another when i read threads like this Link to comment Share on other sites More sharing options...
Mario Posted November 6, 2011 Author Share Posted November 6, 2011 Good progress on this mate. Should be a a stunner by the time its finished. Only thing I dint like is the third brake light delete, personal taste, but think it looks weird without it!? Thanks mate, wont be long now. Link to comment Share on other sites More sharing options...
Mario Posted November 6, 2011 Author Share Posted November 6, 2011 not kean on the centre brake light removal but this is going to look lovely. makes we want to build another when i read threads like this Cheers Rob, another build:d Went through all the pages of you're build thread a few months ago, and i have to say stunning build even the gearbox you have done, excellent mate. But if you start a new one i will be reading the same amount of pages with joy. Link to comment Share on other sites More sharing options...
Mario Posted November 25, 2011 Author Share Posted November 25, 2011 Latest picture i received today, They now started with installing the bodyplastics back onto the body, won't be long now,,,,,,, Link to comment Share on other sites More sharing options...
