fitting mesh
welshbuddy
hey guys, on saturday im going to fit some new MESH =], the lad before me had mesh in his garage, its the first time, iv had a proper look at it, and i love it :p so..
how do you guys fit mesh :D attachements?
NOW FITTED!!
in the end, when i pulled the old stuff out, *looked horrid and dirty*, there are 4 wires holding it, i have now had the wires tucked in abit around the mesh, and glued the wire to the mesh, through the hole, its worked so far, but im not sure at speeds of 120mph ( NOT! public road ;) ) if it will stay in? because of the small holes and not enough of air gets through, well we will see :p!
cheers daz.
Edited by welshbuddy (see edit history)
I have a Do luck front and want to mesh it to provide a bit of protection to the FMIC. My current idea is to use zip tie anchors ...
http://images.cableorganizer.com/adhesive-clips-bases/images/01-adhesive-base_red-cable-tie.jpg
You wont see these as they will be on the inside so even with decent metal mesh and enough anchors it should hold in place well. Cant see many other options?. Where can I get metal mesh that I can cut to fit?
