Silece2k6 Posted April 14, 2011 Share Posted April 14, 2011 hi everyone! Is it possible to change the VSS "without" removing the Cylinderhead? I'm asking about to save some money, because of buying Only the seals or a complete Engine-Kit. On a friends skyline yu can change without removing the head It may save a lot of work greetings Patrick Quote Link to comment Share on other sites More sharing options...
caseys Posted April 14, 2011 Share Posted April 14, 2011 Hi Patrick, I'm sure there's a guide on here somewhere (I am looking for it for you) In the mean time there is this http://www.mkiv.com/techarticles/valve_stem/index.html Simon EDIT : In fact here is the club guide by the very good mr TLicense http://www.mkivsupra.net/vbb/showthread.php?49859-How-To-Valve-Stem-Seal-Replacement Quote Link to comment Share on other sites More sharing options...
Silece2k6 Posted April 14, 2011 Author Share Posted April 14, 2011 Awesome Dude. That may help a lot. THANK YOU!!!!! ) Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 14, 2011 Share Posted April 14, 2011 Did mine using compressed air to hold the valves shut with no dramas. Quote Link to comment Share on other sites More sharing options...
Silece2k6 Posted April 14, 2011 Author Share Posted April 14, 2011 Did mine using compressed air to hold the valves shut with no dramas. The same I'm going to do But I am not sure what I should buy from Toyota. Only the Seals? Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 14, 2011 Share Posted April 14, 2011 I changed quite a bit on mine, the aircon rad wasnt in great condition so replaced it along with the water pump, new auxilary belt and cambelt inc tensioners, new cam cover seals inc the ones on the bolts, new plugs, new coolant and engine oil and filter. Quote Link to comment Share on other sites More sharing options...
madwoody1 Posted April 14, 2011 Share Posted April 14, 2011 did mine with some rope worked a treat Quote Link to comment Share on other sites More sharing options...
