Flushing out a stock auto TC
Jamesy
You can do the flush yourself
MsdPAadc9fY
If you disconnect the return side of the cooler you'll flush the cooler as well, and rather than leave the engine running you can pump out a couple of litres then add a couple of litres, pump out a couple of litres then add a couple of litres, pump out a couple of litres then add a couple of litres...
MsdPAadc9fY
What James is after is fitting a stock tc to his boostlogic trans.
My concern is getting a tc of unknown history and it potentially having debris inside.
If he then has it fitting the debris will munch his trans in no time.
The method you have posted is fine if your looking to flush your trans out,but to do this would mean fitting the tc 1st,
then there is still the possibility of the trans becoming contaminated
Ahh yes please fella ;)
Dude is also checking if the stock TC will handle the power ... :)
Like I said Jamesy the PI will have a lot of uprated stuff in it so I would not hold out too much hope. Have you checked on Supraforums to see what they think. BTW I think stock stall speed is abot 2700rpm.
Stock stall would be between 1800-2000 but higher in yours and a stock converter will destroy itself, a PI has a billet back plate, furnace brazed fins and Torrington bearings, the TC WILL take out the trans if implodes, you will have to fit another lower stall PI or this will cost you a fortune and besides the car will drive like a POS with a stock converter in it.
