Rear Wishbone - How much? + Coil Packs?
neilp9876
Ive got my car in for a MOT / Service and the cost is adding up very quickly :(
One of the parts needed is the nearside rear wishbone which is apparently £500 + from Toyota for the part.
What alternatives are there to this, are there aftermarket ones or can they be refurbished in any way? Or is the price a bit excessive at all?
Edited by neilp9876 (see edit history)
Whats failed on the Arm and is it the upper or lower? I assume based on price quoted its the lower arm?
Aftermarket arms are quite expensive too.
If its the bushes you can get replacements from Powerflex and R2 racing
I had mine done with R2 racing bushes but i dont know if R2 has packed up now.
Or you can give Keron a call i am sure he will have a 2nd hand good condition arm he could sort out for you.
Guest wantthatone
im pretty sure there only available from mr T, however you could re bush if thats where the play is, there may even be aftermarket tuning ones available but secondhand may be your best bet, speak to keron on here, or dunk he replaced his iirc
Its the upper arm which has play in it.
The garage doesnt really want to re-bush it since they think that if the bushes have gone then the ball joint will go as well shortly after so I may as well replace the whole lot now. Whifbitz have them a fair bit cheaper but I will check Keron now just in case.
Fair play mate, £500 is too much for the upper arm so defo get off Whifbitz or Keron :D
My bushes were pretty tired before i replaced them, when re-bushing the balljoints were fine.
I re-bushed the car now around 3 years ago and no issues with balljoints.
The lower main arm is much cheaper than the upper arm (Retail £227 inc vat) , the upper rear is the most expensive out of all of them and the last price i got a couple of months ago
was (Retail £430.81 inc vat)
I got a chunk of discount off that price and to me it was £344.48 inc vat.
Give Steve Manley at Inchcape Toyota Oxford a call on 01865 291333
From what i've read the bush kits aren't worth fitting but i've no personal experiance with them as i replaced all mine with new o/e from Toyota
Guest wantthatone
i would have to disagree there dunk, i fitted the R2 kit, feels amazing now. tight & responsive
As i said i've no personal use but heard some people weren't impressed, the rear upper arm doesn't just have plain bushes if my memory serves me correctly but if your happy then its a much cheaper fix if the bushes you fit last and the ball joints also last.
Powerflex do not do the rear wheel wishbone bushes, only the front suspension. R2 racing seem to have disappeared, I can find references to them on US sites but nothing over here so they could be hard to get hold of.
I guess its either Kieron or Mr T then!
Edit - Whifbitz do "SuperPro" bushes, I guess these would be similar to R2 or powerflex in terms of quality?
Also - Coil packs.
Theyve told me I need to replace these, is there any particular symptom for them breaking down or are they a service item? Theyre pretty expensive and I was wondering whether or not I need to have them replaced?
EDIt : its just the clips so it doesnt matter.
Thanks for the advice guys.
And just to level things up, I'll agree with dnk. Replaced both upper rears for new from paul last year. was the best price I found and car is 10x better now even though there was only very tiny amounts of play in 1 side. The ball joints on the new ones were much firmer than my old ones. I also have no experience with rebushing. but the ball joint on mine was 17 years old. I'd rather not take the chance with expensive bushes, and a pain in the arse job from what I've heard. If you go secondhand, make sure you buy from someone reputable who can tell you the age/mileage, Both of these are important as rubber has a tendency to age badly.
I also replaced the coil pack clips last year, only because mine disintegrated. The difference was amazing. I obviously had a slight misfire before changing. After the change the idle was rock solid and just sounded 'sweet'
Rob
The Superpro bushes are very good and a cheap way of getting both rear upper arm bushes changed. We fitted a full bush kit on Steve Lintons race car he reported back a huge change in the way the car felt and handled, worth every penny.
