Benje1990 Posted April 12, 2011 Share Posted April 12, 2011 hey people, yesterday my TT started making a strange sound at low revs 800-2500rpm.. basicaly its like the sound u get if your driving at lets say 30MPH and you stick it in 6th gear you get that sorta struggling vibration sound... now i no the sound is not the engine as she runs sweet as a nut... the sound can also be heard and a standstill in nutral with the clutch released, if u dip the clutch and rev it you can hear this sound... theres no power loss and she dont drive any diffrent its just a noise. i use to own a MR2 turbo 18months ago and i had a similur sound on that turned out to be the prop shaft bolts vibrating them selfs lose..:S apprantly a common problem on them cars!?... il have to get under her tomorrow after work but any ideas would be a great help. i dont belive its the gearbox as she shifts like a beaut no nochyness or snaching, so slightly puzzled, also feel its getting slightly worst. or i may just be noticing it more now lol. cheers, sorry about spelling im tired long day lol **benje** Quote Link to comment Share on other sites More sharing options...
TTRickeh Posted April 12, 2011 Share Posted April 12, 2011 Crank pulley? Is there a bit of a squeek at start up? Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 12, 2011 Share Posted April 12, 2011 mr2 has a prop shaft? Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 13, 2011 Share Posted April 13, 2011 At a standstill, the props not moving so it's not that. Probably a knackered release bearing. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 13, 2011 Share Posted April 13, 2011 (edited) Whereabouts is the noise coming from? If you can let us know that, it'll help diagnose what the problem may be. Edited April 13, 2011 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 13, 2011 Author Share Posted April 13, 2011 il have to have a listen later + get a mate to rev it a little wile i listen because the noise cant be heard at idle... cheers tho. Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 13, 2011 Author Share Posted April 13, 2011 Hey guys been out at lunch with a friend!, can confirm its defo the gear box.... can also confirm its after the clutch and fly and more internal to the box,. my friend who builds 800HP skylines, recomends first protocal should be to change the gear box fluid as the car has only been in the uk for 7 months and no record of the last change?, he also said that these box's (6speed manual) Are Very strong and as my car is only running 360BHP it should be un damaged. The box has 75k miles on it (yes miles). any other input would be great guys cheers! Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted April 13, 2011 Share Posted April 13, 2011 How did he diagnose that?. Was the car up on a ramp? Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 13, 2011 Author Share Posted April 13, 2011 you can make it make the sound if u blip the thorttle on stand still makes the sound with the car in nutral stops if u depress the clutch!?... car wasnt on a ramp we just head under car sorta thing... He just came back around and said that one of his gear box rebuild guys refuses to belive this and said its way more likly to be the duel mass fly wheel... hopefully it is the fly wheel but i didnt even no this car had a duel mass lol Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 13, 2011 Share Posted April 13, 2011 Clutch or flywheel imo Quote Link to comment Share on other sites More sharing options...
Benje1990 Posted April 13, 2011 Author Share Posted April 13, 2011 another member had this problem last year he had a solid flywheel and an uprated clutch thats his video mine has the same sound! not as lound as his but belive its the same i have PM'd him as his thread ended with no result... Quote Link to comment Share on other sites More sharing options...
Nic Posted April 14, 2011 Share Posted April 14, 2011 Has the noise just started or have just got the car and it's like that? A solid lightened flywheel transfers a lot of the gearbox noise and can make the car sound like a bag of hammers at tickover, when the clutch is pressed the noise will go. Also if the revs are raised above 1K rpm the sound from a solid flywheel usually goes. If yours is still noisy at 2.5K rpm then I'd guess it's either clutch or bearing related. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 14, 2011 Share Posted April 14, 2011 my friend who builds 800HP skylines Does he build 760hp skylines? Do you think he could build an 810hp one, or would that be too much? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2011 Share Posted April 14, 2011 It's strange how many poeple have "friends" that build race tuned 90000000bhp (insert a car here) cars, wish I had a mate that did! might be able to get some free stuff Quote Link to comment Share on other sites More sharing options...
