Pudsey Posted April 12, 2011 Share Posted April 12, 2011 Hi there, I have the following Part for sale........ Part Name: - Race Logic Traction Control, with adjuster and launch control with leads and cd. Condition: - Excellent used fully working condition, just removed from my car. Was set up by our very own Smarty at Santa Pod. Picture Available: - Sale Price: - £420. Postage Arrangements: - Price Inc Postage in UK. (Overseas please enquire). & There will be no dibbs unfortunately, as I have tried that and it didn't work out. The first person to pay will secure the item. Pay Pal fees must be paid by the purchaser I am afriad. Availability Status: - Sold - Payment has been received. http://www.mkivsupra.net/vbb/showthread.php?243929-Brand-New-Power-Enterprise-800-cc-VVT-i-Fuel-Injectors-(Set-x-6 http://www.mkivsupra.net/vbb/showthread.php?244022-Chris-Wilson-VVT-i-1st-Decat-Pipe-Full-Stainless-Steel-with-1.0-bar-Restrictor-Ring http://www.mkivsupra.net/vbb/showthread.php?244302-Brand-New-Setrab-Auto-Gearbox-Cooler-AN-Fittings-Braided-Lines http://www.mkivsupra.net/vbb/showthread.php?244300-Brand-New-Setrab-19-Row-Oil-Cooler-AN-Fittings-Braided-Lines http://www.mkivsupra.net/vbb/showthread.php?244298-Brand-New-Whifbitz-Twin-Electric-Fans-and-Shroud http://www.mkivsupra.net/vbb/showthread.php?243932-2-x-Cobra-Misano-(Black)-Alcantara-and-Half-Leather-with-Real-Carbon-Fibre-Seats http://www.mkivsupra.net/vbb/showthread.php?244021-UK-OEM-Bonnet-Scoop-(Painted-Red)-with-associated-fitting-parts-(Brand-New http://www.mkivsupra.net/vbb/showthread.php?244020-Blitz-SDC-ID-S-Boost-Controller-amp-Power-Meter http://www.mkivsupra.net/vbb/showthread.php?243921-Race-Logic-Traction-Control-System-with-adjuster-and-launch-control-with-leads-and-cd http://www.mkivsupra.net/vbb/showthread.php?243911-1-x-HKS-Pulley-Cam-Timing-Adustable-Tuning-Pully-Wheel http://www.mkivsupra.net/vbb/showthread.php?243910-Blitz-Lower-Front-OEM-Manual-Overide-Spoiler-Controller http://www.mkivsupra.net/vbb/showthread.php?243858-1-x-Sabelt-Race-Harness-4-Point-(4-inch)-Dated-FIA-2010-(Black-amp-Yellow http://www.mkivsupra.net/vbb/showthread.php?243857-1-x-Sabelt-Race-Harness-4-Point-(4-inch)-Dated-FIA-2015-(Black-and-Yellow Link to comment Share on other sites More sharing options...
Bailey. Posted April 13, 2011 Share Posted April 13, 2011 Am I right thinking there is a Abs and non abs rltc setup??? Which is this? Link to comment Share on other sites More sharing options...
mwilkinson Posted April 13, 2011 Share Posted April 13, 2011 All rltc require abs. One kit, as above come with the ecu and controller and the other you would need to buy the ABS sensors from Race Logic. Even without ABS you can buy the above and then buy new ABS sensors from Race Logic. Link to comment Share on other sites More sharing options...
Pudsey Posted April 13, 2011 Author Share Posted April 13, 2011 Am I right thinking there is a Abs and non abs rltc setup??? Which is this? All rltc require abs. One kit, as above come with the ecu and controller and the other you would need to buy the ABS sensors from Race Logic. Even without ABS you can buy the above and then buy new ABS sensors from Race Logic. Many Thanks you are 100% correct. The Race Logic is ready to fit to any car that already has ABS fitted as standard. If you don't have ABS, you would need to purchase the sensors as the system requires them to measure wheel speed and rate of change. NB: The kit I am selling doesn't come with ABS sensors, if it did it would be much more expensive I would imagine. Link to comment Share on other sites More sharing options...
Bailey. Posted April 13, 2011 Share Posted April 13, 2011 What's the fitting time on one of these fella are they a pita?? Open to offers? Link to comment Share on other sites More sharing options...
Rob W Posted April 13, 2011 Share Posted April 13, 2011 Wiring these in is quite easy I thought. Fitted mine in about 5-6 hours, there is a "how to guide" on the forum mate. Well worth the money, great piece of kit. Link to comment Share on other sites More sharing options...
mwilkinson Posted April 13, 2011 Share Posted April 13, 2011 Wiring these in is quite easy I thought. Fitted mine in about 5-6 hours, there is a "how to guide" on the forum mate. Well worth the money, great piece of kit. Agreed. Quite straight forward, just get the pin diagrams for the wiring from the forum and your ready to go. Took me about 5 hours to intall and calibrate. Link to comment Share on other sites More sharing options...
Pudsey Posted April 13, 2011 Author Share Posted April 13, 2011 Very easy to fit. All you need to do is locate and bridge all of the injector wires x 6, Locate and 'tap' into the ABS wires for a reading. Earth and Power from a 'Live' Switched Ignition source, from ignition barrel. I have the instructions for fitting, and probably the wiring diagram too although mine was VVT-i at the time. Thanks everyone for the help - and kind pointers. Link to comment Share on other sites More sharing options...
Pudsey Posted May 19, 2011 Author Share Posted May 19, 2011 I still have this item available. Many Thanks Link to comment Share on other sites More sharing options...
Pudsey Posted May 30, 2011 Author Share Posted May 30, 2011 Now Sold - Many Thanks Link to comment Share on other sites More sharing options...
