spiderpigcity Posted April 11, 2011 Share Posted April 11, 2011 just a question, when doing a manual conversion do you need to change the ignition barrel then? Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 11, 2011 Share Posted April 11, 2011 Say What! Why would you need to do that??? In answer to your question... No But where did that come from??? Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted April 11, 2011 Author Share Posted April 11, 2011 well i put an advert on here for a lock set with keys and ignition barrel. someone asked me if it would fit an auto as the barrel came off a manual 6 speed. i couldnt answer the question, it had me thinking if my barrel on my auto needed changing when i do the manual conversion Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted April 11, 2011 Author Share Posted April 11, 2011 something to do with the cable from the selector on the autobox in park Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted April 11, 2011 Share Posted April 11, 2011 (edited) just a question, when doing a manual conversion do you need to change the ignition barrel then? auto to manwell conversion Keh! Edited April 11, 2011 by Tricky-Ricky (see edit history) Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 11, 2011 Share Posted April 11, 2011 Say What! Why would you need to do that??? In answer to your question... No But where did that come from??? hes from barcelona Quote Link to comment Share on other sites More sharing options...
Scott Posted April 11, 2011 Share Posted April 11, 2011 Say What! Why would you need to do that??? In answer to your question... No But where did that come from??? The auto barrel has a lock so that you can't take the key out until the shifter is in park Not sure if the 6spd has the lock or not, certainly isn't active though. Quote Link to comment Share on other sites More sharing options...
spiderpigcity Posted April 11, 2011 Author Share Posted April 11, 2011 so it is different then. the guy was right the manual one wouldnt fit his auto cos he would have nowhere to stick his cable [sHOCK][/sHOCK] Quote Link to comment Share on other sites More sharing options...
keron Posted April 11, 2011 Share Posted April 11, 2011 the barrels are the same...ive interchanged loads.... Quote Link to comment Share on other sites More sharing options...
RobUK Posted April 12, 2011 Share Posted April 12, 2011 the barrels are the same...ive interchanged loads.... Redeemed..... I did think it was the oddest thing I had heard about a manual conversion! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 12, 2011 Share Posted April 12, 2011 Its only a little solenoid on the ignition barrel, just remove it. Quote Link to comment Share on other sites More sharing options...
