need some info on first cat and turbos on supra
mikeyh
today i removed the fcon and put it back to standard on the ecu.i also changed plugs to bcpr7es gapped to 0.85 but still no change the only thing i can put this down to is either coil packs or boost controller wired up wrong. has anybody got a coil pack i can borrow just for trial or error. because the last thing i want to do is buy coil packs and its not the problem
i have a set of coil packs which you can borrow as long as you pay for postage. ;)
my missfire turned out to be faulty coil packs ive know sourced some through cj putting her on the rollers next week to check fueling and make sure everythings doing what it should be :clap:
id like to give a big thanks to absxxx for lending me his coil packs to see if it was the problem :respekt:
also a big thanks to ian c and all you guys for your help it was a big help :respekt: :clap:
