Gearbox/clutch problems?
spidermonkey
first try bleeding the system . . might just not be pushing the fork far enough due to air od poor fluid condition
then it could be the release bearing . . does it get hard to select gear once youve been driving for a while?
gearbox oil change can also make a big difference
bushings on the shifter . . toyota ones can get pretty deformed in some cases (on my w58 the bushings which suport the remote shifter asembly had disintergrated causing a very poor shift)
i would check all these things befor taking the box appart
I seem to have a problem selecting gears on my 94 TT, I have a V160 gearbox, I have no clutch slip once engaged, Could I need a new clutch?
Try accelerating from 2K rpm in 4-5th gear, this will pull a lot of load on the clutch, if it is worn and slipping you will hear/see the revs rise faster than the car accelerates.
