mikerunner Posted April 10, 2011 Share Posted April 10, 2011 on the hunt for a clutch to hadle up to 500bhp and a stock flywheel near to new would be great Link to comment Share on other sites More sharing options...
Swampy442 Posted April 10, 2011 Share Posted April 10, 2011 Which gearbox? Link to comment Share on other sites More sharing options...
mikerunner Posted April 10, 2011 Author Share Posted April 10, 2011 oh yea, manual 6 speed v160 Link to comment Share on other sites More sharing options...
JamieP Posted April 10, 2011 Share Posted April 10, 2011 http://www.mkivsupra.net/vbb/showthread.php?242225-Centreforce-Dual-Friction-clutch-stock-flywheel Link to comment Share on other sites More sharing options...
mikerunner Posted April 10, 2011 Author Share Posted April 10, 2011 missed it by bout an hour, gutted Link to comment Share on other sites More sharing options...
mikerunner Posted April 10, 2011 Author Share Posted April 10, 2011 is the clutch still for sale? Link to comment Share on other sites More sharing options...
mikerunner Posted April 11, 2011 Author Share Posted April 11, 2011 got a flywheel, need a clutch Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 12, 2011 Share Posted April 12, 2011 My uprated stock clutch might suit? I use the stock, brand new driven plate, as it is correctly balanced, doesn't judder and will hold all but mega torque highly modded engines or cars used for drag racing. I modify a stock brand new cover to give more clamping force. The reason I tooled up to do these is some of the aftermarket US clutches I have fitted SEEM to be built from used cover assemblies with reground friction surfaces, and a stronger spring. I have had hellish trouble getting these to fully release, because due to this seemingly thinner cast iron friction face, the geometry of the clutch goes to pot, and being a pull type clutch (the hydraulics pull the bearing away from the engine, rather than the more normal push type) it is a lot harder to effect a cure. For 455 pounds plus VAT , you get a brand new driven plate, a brand new modded cover, and a brand new release bearing. I would rather fit myself so any complaints are down to me, I see a lot of clutches damaged by people without the right gear (a ramp and transmission jack, plus correct circlip tools and fitment) or clutches fitted to patently *uggered flywheels. I will do a supply only if you feel competent to tackle the job or are using a bona fide garage to fit the clutch Toyota use a dual mass flywheel (the flywheel is in 2 parts, an inner and outer assembly, damped in the middle) which is now showing signs of wear causing a lot of rattle when idling or on very light throttle openings. For God knows what reason they are charging about £270 + VAT for a new one, they look more like they should be over 500 to me, but don't say anything :-) The very similar LUK dual mass flywheel on Maseratis is nearly £1000 + VAT.... So if the flywheels old enough or abused enough to be scored it should be replaced. Fitting by myself will cost £175 + VAT. Link to comment Share on other sites More sharing options...
