TT engine
RobD
Bought this of jurgen last august, its currently stripped.
2 options.
1. Engine is built up with the following used...
Toyota oem piston rings
ACL Bearings (main, rod and thrust)
ARP Head Studs
ARP Rod Bolts
ARP Main Bolts
New OEM gaskets including Head gasket
Ferrea Valve Stem Seals
2. Engine is put back back together using original bearings etc with the following...
New OEM Piston Rings
New OEM gaskets throughout including Head gasket
The head has been skimmed and cleaned
Valves have been cleaned up and reinstalled
Block will be sent away for a skim this week ready to be assembled.
The water pump, oil pump, cam belt and tensioner has all been replaced recently by the looks of it.
Engine has around 100k kilometres on it, pics found here of engine internals, crank looks like new...
http://www.mkivsupra.net/vbb/showthread.php?237262-RobD-s-NA-TT-Engine-Conversion-thread-)&highlight=RobD%27s
Option 1, £1200
Option 2, £850
Thanks
Decided to build the engine up using original parts, I also have the following to go with it if you fancy sourcing the rest for a NA-TT conversion...
Inlet plenum and throttle body
TT pas pump
Precision Turbo FMIC with Greedy pipes
TT6 Engine Loom
TT6 clock (slighty damaged)
All the above plus the engine with original past and fresh gaskets etc
£1400 pick up only :)
