Crankshaft Position Sensor
CanisLupus
Hi guys after the old faults been resolved i got a hot starting issue.
Now i've checked the Camshaft Position Sensors and the Crankshaft Position Sensor.
And here is my question:
In the TSRM on http://www.turbosupras.com/pages/pages/technical/jza80/a80tsrm.htm it says 1630 to 2740 Ohms cold and 2065 to 3225Ohms hot is OK.
But in this thread: click in post 5 in the pictures there are different values.
Which ones are the right ones for a 1996 Jspec TT? I got 1330Ohms cold and 1530Ohms hot today and according to the first data the sensor would be gone but looking at the second it is ok...
If the sensor is gone i'll order one tomorrow if not i have to continue searching... :(
I do actually have one. What settings should i use and what should a good signal look like?
Didn't have any fault codes :\
Thing is the car starts cold without any problem and runs fine. When it gets warmer i can hear almost non perceptable and short cut outs on idle and it won't start until it is cooled down again. Don't know if there are other problems because i only drove it a little bit and it seemed ok.
i recently had the same issue as you, and my crank sensor tested ok, or within spec anyway with an ohm meter.. it still turned out to be faulty. starting fine when cold, once it warms up it cuts out and wont start till its cooled down again. it was about €100 but easy to swap out
