engine sensors
Rob_Mitchell
On the actual block itself, I don't think there's many at all from memory.
2 X knock sensors - intake side, cylinders 2 & 5 IIRC
1 X crank position sensor - left hand side at the bottom (tucked below the alternator if that was on)
1 X oil pressure - can't remember right now
Nothing else comes to mind right now.
You can see the knock sensors here.
2 head stud up on the right, directly on the right is a sensor with a plug and wire coming from it, that's number 1, then go to the 5th stud up one the right, and on the right you can just see the 2nd knock sensor
(pic is an aristo, but same locations)
http://gallery.me.com/garage2you/100084/IMG_0604/web.jpg
