Built sub & amp setup
Jonny5
Ok I have decided to remove my Sub set up from the boot of my supe.
This setup is probably one of the most quality bits of kit I have ever had the pleasure of hearing, let alone feeling, but it's not really my thing..
The setup consists of a fully custom built twin sub enclosure with built in amps, cooling fans mounted either side. Fits snuggly behind the rear seat.
Spec:
Genesis Dual Mono series 3 amplifier, 2 channel
Genesis Mini Block series 3 amplifier, 1 channel
(These amps are of the highest quality, hand built in London, they come with certificates indicating actual power output having been individually tested, link to website below)
2 x JL audio 12W6v2-D4 subwoofers 600w
2 x ZR-650-CSpxo crossovers
Now this little lot for speakers & amps add up to a little over £2K, without the enclosure:
http://www.incarexpress.co.uk/view_product.php?partno=12W6V2D4
http://www.incarexpress.co.uk/view_product.php?partno=DUALMONO
http://www.incarexpress.co.uk/view_product.php?partno=MINIBLOCK
http://www.genesiscaraudio.co.uk/global-en/products/series-three.php
Check out the above sites for more info on tech specs, the setup will come with dual amp feeds, all RCA leads, earth leads, fused connections.
selling for £750...
If interested please feel free to PM me..
cheers Jon
