Bosses and sensor mounts
Andy-No-Knee
Anyone know where I can get mounts to place the sensors in?
I have EGT, and I want to attach it to the 6th runner on the HKS manifold (single) but I need to get a boss mount the right size then get it welded on.
Oil temp (for the auto box) I need a small block that will fit in line, fill with oil and take the sensor in.
Water temp, what I'm after is not the ebay special where you have to cut a hose and place a unit in as I have a water bypass kit - but one where I can screw the sensor into a mount as there is a boss already fitted to the hard top pipe of the bypass kit.
Thanks Chris, its the adaptors I'm after....do you sell them or just the probes?
Water temp - I have a water bypass kit that takes a feed from the water pipe at the rear of the engine and brings it to the top rad hose. The top rad hose is a metal pipe with a housing already welded on and I need an adaptor to make the sensor fit the housing.
With the SS adaptor for the EGT sensor - what thread/depth does the sensor need to be?
Also, do I have to use the sensors that came with the gauges or can I use any sensors, ie ones from you.
An EGT probe is just that, basically a thick piece of wire type thing, usually of 3 mm OD. The fitting uses an olive to clamp and seal the probe so the right amount sticks in the exhaust gas stream. You can use any K type probe with 99% of EGT gauges. Water temp sensor and oil temp sensor need to match the gauges or they may not work right, or even be damaged..
